![]() ![]() ![]() Drives: 2009, auto, 4dr LB Join Date: Nov 2010
Been awhile since I've posted. Frankly, car has been great so..........however thought I'd share my belt story.
Changed my serpentine at 90K miles, have since rolled over 100k, used an OEM belt and the DIY tensioner mod found on the forum. Really nothing to it, about $40 all in belt and tensioner, and maybe 15 minutes with a dremel modding the tensioner. Prepped the alternator bolts a couple of days in advance with some PB blaster, loosened right up. Couple of minutes to thread around the wheels, initial tension using the "twist" method mentioned already in the forum. Tightened up the bolts, found the lower bolt very easy to deal with using a six sided stubby wrench. Oh yeah, gloves. Make sure you wear gloves. Don't want to slip off anything using any amount of force down there. About a week after install I got a "chirp" on start, went and loosened the bolts, couple of turns on the tensioner, checked the "twist", tightened it up, no problems since. cheers. PIC - https://www.dropshots.com/NEexpat/da...04-05/16:16:35 *Still trying to post the link to the video here, however if you go to the above link and click on 2018 in the right hand column and scroll down a bit you can see the video there. Anyway............................... Last edited by NEexpat; 06-25-2018 at 02:51 PM. |
| Tags |
| belt, squeeling |
| Belt Squeeling. | alweasel | General Yaris / Vitz Discussion | 4 | 09-27-2019 11:07 AM |
| Oil change shop says alternator belt is cracked | RMcG | DIY / Maintenance / Service | 19 | 05-02-2018 07:38 AM |
| Blitz Supercharger Belt Slip @ Higher RPM? | Freestylin | Forced Induction Forum | 20 | 09-06-2017 07:32 AM |
| Belt Squeeling like a Mofo | gumby002 | DIY / Maintenance / Service | 7 | 09-10-2016 05:38 PM |
| DIY how to change you belt in 10 minutes without breaking VVTI solenoid | YarisSedan | DIY / Maintenance / Service | 2 | 04-12-2013 10:41 AM |
