Old 07-06-2018, 02:45 PM   #1
zoidberg444
zoidberg444's Avatar
Damn. That really isn't bad for a DIY spray job.
The Gunman on YouTube makes it look so easy.
- Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles
UK to Nordkapp in a Yaris
Old 07-06-2018, 04:41 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Thanks! I definitely learned a lot. Next time, I'll block sand with guide coat. It was very stupid of me to not do that. I think I would have had a much, much better job had I done that. I basically rushed the job at the end. What I would give to back up 3 days. I have to keep in mind that it is a 12 year old car and it's got other signs of wear and tear. That said, I do feel regretful that I didn't take the time to properly sand.
There are some spots where the clear is not as thick as others. It's still a good covering in those spots. But, I would defintely pay closer attention and plan out a strategy. It's very easy to forget where you left off.
Overall the car looks decent, I suppose, in that it is all one color and fairly glossy. I'm having second thoughts about color sanding the clear coat. One, I don't want to run the risk of cutting into the base coat and two, it would only make the flaws in the base coat more pronounced.
DIY: Painting Engine Cover frownonfun DIY / Maintenance / Service 12 11-30-2013 11:07 PM
Stripping Paint Without Sanding CrystalJean DIY / Maintenance / Service 1 10-06-2012 04:06 PM
Advice on paint booth CAyaris DIY / Maintenance / Service 12 02-11-2011 09:37 AM
New 2007 Paint Condition Pavel Olavich DIY / Maintenance / Service 16 09-13-2009 04:14 PM
