#37 |
![]() Drives: 2007 yaris Join Date: Jan 2018
So I just changed the water pump radiator and thermostat and I’m still having overheating problems ... and tips or help I can get is appreciated!!
#38 |
Define overheating - what are you experiencing? Could be a bad rad cap, could be a faulty coolant temp sensor, could be a blown head gasket etc etc
#39 |
I can drive the car for about 15-20 minutes before it goes hot also when the ac is on it goes hot faster
#40 |
Are you positive you put enough coolant in the car? You might have an airlock. I've done many coolant changes and the Yaris purges air pretty easily if you have enough coolant in the system. If you have a smart phone you can pick up Torque Pro app and a cheap OBD2 bluetooth adapter (everything for under $20.00) and monitor coolant temps. That's what I use so as I approach ~180 F, I start feeling the upper rad hose for heat to see that the thermostat is opening.
#41 |
yeah I’m positive it has enough coolant... just today the coolant was spilling threw the resivor tank
#42 |
Yaris Hybrid Limited 2015
And the electric fan is running, it should run when the AC is on.
And on mine 2013 the rpm on the fan increases when the coolant get hot. So it could be the thermoswitch on the coolant.
#43 |
Pull the rad cap while cold, start the engine and let it heat up. If start seeing bubbles you have a head gasket leak. Had that happen on an old CRX race car I used to crew for.
#44 |
I tried the rad cap all I get is a couple air bubbles... could it be a bad thermostat?
#45 |
![]() ![]() Drives: 08 Yaris AT, 350Z GT MT Join Date: Feb 2013
If everything started when you ran the car with low coolant level I think air could be the problem.
Double check all your work and flush the whole system as instructed in the water pump replacement guide. Properly fill and bleed the air out of the system, use toyota coolant. |
#46 |
Got it... thanks for all the help really appreciate it
| Tags |
| coolant, heater, overheating, radiator, thermometer |
| Water Pump issue, after taking in for Recall | GeneralDon7 | General Yaris / Vitz Discussion | 34 | 05-27-2012 08:04 PM |
| ATX temperature overheating? | yaryarbing | Fuel Economy Forum | 7 | 05-07-2011 09:24 AM |
| 2007 Yaris Door Lock Issue | bhola | General Yaris / Vitz Discussion | 7 | 10-05-2010 12:01 AM |
| heater control box issue | DevilGirl | DIY / Maintenance / Service | 12 | 01-08-2010 03:45 PM |
| CONSUMER REPORTS : MARCH issue reviews '09 YARIS . | gid | General Yaris / Vitz Discussion | 93 | 01-06-2009 04:10 AM |
