Old 09-11-2018, 07:20 PM   #3
Runethecursed
Drives: 2009 Yaris S
I have no steps but can confirm, to fully remove the dash you need to remove the driver and passenger A pillar trim, the door liner, and then pull the radio trim, the radio bezel, the radio itself, the gauge pod trim, the gauge pod, then open the cup holders theres a screw in them on both sides, then work your way around the steering wheel, and also be sure to remove the glove box ( the actual one on the bottom of the passenger side) then remove most those bolts from holding them down.
I took mine in an out a few times and cause I am lazy i only installed like 1/3rd the stuff to make access way easier. But it is a pain, expect to spend a lot of time and as for getting the front panel to line up. a solid thwak.
Runethecursed is offline   Reply With Quote
Driver's Side Seat Question - 2009 Yaris Sedan 03mazpro New YARIS Purchase Forum 1 02-19-2016 04:01 PM
Vibration problem with Yaris SEDAN 2009 Rohail DIY / Maintenance / Service 12 11-20-2012 02:53 AM
2009 Yaris Sedan vs 2009 Scion XD Jungle Rot New YARIS Purchase Forum 32 02-23-2009 05:40 PM
