Old 11-03-2018, 09:58 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Thanks Tom. Defintely the same configuration, but different wires. Not sure if they serve the same functions as I haven't looked at the Corolla diagrams much.
Down the rabbit hole...
If I actually got a 2008 xD ECU, then it appears - in its stock form- to be incompatible with both my harness and transmission. For one thing the 2008 ECU only appears to feed 8 wires to the connector. And, the SLT+ and SLT - pins are not the same between my Yaris and the xD harness.
From what I'm seeing - from my limited understanding - I need a different ECU, or figure out if the one I have will work and I need to swap some pins in the harness at the ECU. I still have to look at my ECU overall to be sure that those spots even have pins and if they are assigned to something else.
I will try to refrain from asking a lot of questions as I've done an awful lot of that over the past couple months. But, feel free to chime in if you are so inclined.
Once this is all over, I'll spend some time cleaning up my thread.
Old 11-04-2018, 01:06 AM   #2
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
Wow. I apologize. I wasn’t aware they changed the pins in 2011. So it looks like you need to do the same pin swap I had to at the ECM. Here is the link to how I did it:
http://www.yarisworld.com/forums/sho...t=56031&page=5
So it looks like at some point they started using corolla parts on the xD, right before it was discontinued. Great work pulling up the info!
Old 11-04-2018, 07:28 AM   #3
06YarisRS
Thanks Tom! I really appreciate the explanation of how it works. How could you possibly be aware of every change that is made by the manufacturer? I just looked at your link to your pin swap.
It looks like I do have to swap 57 to 58. The 2008 xD does not reference Pin 9 at all. I wonder if that is why it is grounded. There is no mention of SLU+ and SLU- on the 2008 pinout. I wonder if I need a different ECU.
Here is an update picture that includes a 2009 Corolla. As far the 2009 Corolla and 2011 xD ECTS is concerned, the pins are identical. I still can't get my head around the changes in the xD ECU between 2008 and 2011.
I am wondering if I should just go out and do as you say - switch 57 to 58, ground 9 and test it.
Old 11-04-2018, 01:11 AM   #4
ArmstrongRacing
Data doesn't lie
If you want to know how all of these ECTS wires work and why ill give a brief explanation. Each one of the inputs corresponds to a solenoid, these solenoids move when activated by the ECM and allow line pressure(about 800psi) to activate their wet clutches. The holding and releasing of these clutches manipulate how the planetary gears "simulate" gears.
Solenoids are just an electrical load device, they need a positive and negative circuit to operate. Just like a bulb, here we're moving wires around in the harness to make those solenoid circuits complete.
The Yaris ETCS has a different layout than ALL of the 1.8L cars due to its sub-compact nature. So we are never going to have a simple "plug-n-play" AT swap.
Old 11-04-2018, 08:40 AM   #5
atomic_hoji
Drives: 2018 Yaris SE 5MT
At work, can't play with diagrams, but given what you have there I can see your problem..
All pins trans side are consistent in function (same trans), BUT - pin 9 should be ground as Tom noted; the 2008 ECM doesn't supply an SLU-, it uses a local ground instead it looks like.
At the ECM the 2008 and 2011 xD differs on pins for SLU+/- and SL. Pin 57 on your 2011 harness needs to move to pin 58 to match the 2008 ECM; you've already cut the wire at pin 77 - just make sure it's not used elsewhere and is taped and isolated to avoid issues..
-- Adam
atomic_hoji is offline   Reply With Quote
Old 11-04-2018, 09:59 AM   #6
06YarisRS
Thanks Adam! I'm going to do the swaps as per Tom's and your directions. At hockey again today, so it will be a bit later. I'm going to practice removing ECU pins on my Yaris harness before tackling the xD harness in the car.
I will definitely post back with the results.
Old 11-04-2018, 11:51 AM   #7
06YarisRS
I cannot for the life of me get these darn terminals out! I am practicing on my spare Corolla harness that came with my engine. I'm in the correct release hole, wiggling the safety pin around, the white slide lock is pushed out the required mm. Maybe my pin is too small. I've looked at a close up pic of the actual terminal.
Old 11-04-2018, 12:29 PM   #8
06YarisRS
OK, finally managed to get a couple of pins out. How easily should they come out? It took a bit of force and made a little snap sound. The terminal appears undamaged.
Old 11-04-2018, 01:23 PM   #9
atomic_hoji
My experience is that usually if the retaining bar/clip is fully disengaged and the pin has the internal clip out of the way a bit of a gentle tug will slide it out. Generally force and a snap sound means the plastic internal clip is busted. You can check by reinserting the terminal - it will feel sloppy if broken..
Good news is you're pulling out of one and into another pin slot, so if you break the internal clip you're probably OK, as long as you don't damage the metal terminal; and/or no other terminal needs to use that pin slot.
-- Adam
Old 11-04-2018, 03:13 PM   #10
06YarisRS
-- Adam
Thanks Adam! Well, it is done, but I wouldn't call the pin removal easy. LOL! Of course, since I was doing it on the car, despite my best effort to save the wee rubber plug, it found a new home somewhere in the engine bay! I used a very fine tip on my tube of rtv sealant and put a small dab in the newly opened hole.
Standby for a pic!
Old 11-04-2018, 03:14 PM   #11
06YarisRS
A picture is worth a thousand words...
Thank you gentlemen!!! It was the pin swap from 57 to 58 that cleared the codes. I had 5 - 6 starts, running 5 - 10 minutes each, a similar number of scans and not one MIL, except of course when I jumped in and fired it up without putting the intake tube back on. I got MAF error, but that disappeared after re-install and startup.
I redid conduit and tape around the trans connectors and ziptied everything. It looks great.
One other thing I'd like to do is slightly bend my transmission dipstick tube a touch toward to the driver's side. It's hard to get out past the upper rad hose.
Here is a pic with everything (in the engine bay, at least) put back together.
I am just so itching to take this bad boy for a run.
Old 11-04-2018, 03:46 PM   #12
atomic_hoji
Virtual high five buddy! glad you got it sorted out.
Now get out and go for a rip..
-- Adam
Old 11-04-2018, 05:17 PM   #13
06YarisRS
-- Adam
Thanks Adam! Rip will likely happen tomorrow evening. Gotta get all the panels and such back on.
Old 11-04-2018, 06:13 PM   #14
ArmstrongRacing
Data doesn't lie
Huge congrats to you sir for figuring this out!
Old 11-04-2018, 06:28 PM   #15
06YarisRS
Thanks Tom, but it was you who figured it out originally! I was just riding on your coat tails. You guys have been simply awesome, from my initial inspiration to do the swap, down to the technical details. It's definitely a different thing to break new trail, than to copy what others have done. That said, I'm pretty happy I managed to pull it off. In my first post, I said it would be the most involved car-related project I've done, and that it was. Haha.
Now...time to start in on learning to beef up the 1NZ internals for forced induction....joking!
Old 11-04-2018, 08:59 PM   #16
tmontague
tmontague's Avatar
Congrats on the swap! Enjoy a much needed sleep lol
I'm surprised the 2011 harness is different then the 2008, guess we all learned something new on this swap. This is also one of the reasons I want to put out a thread going over these things.
Old 11-05-2018, 05:42 AM   #17
06YarisRS
Thanks. Yes, I too was surprised but ultimately thankful that it just required the pin swap. Maybe a quick review of wiring diagrams before posting could confirm any other differences in the years if there are any. I could do that as a contribution.
Old 11-05-2018, 04:21 PM   #18
06YarisRS
The auto recycler where I got my used alternator, A/C compressor and engine cover is going to give me a different compressor. So, instead of slapping all the body parts back on tonight, I'm going to remove the compressor. Yet another delay to my first test drive.
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 09:07 PM
2zr swap and e-test in Ontario tmontague Performance Modifications 7 12-23-2016 09:12 AM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
