Old 11-06-2018, 12:36 PM   #1
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Soon...sooooon...
On Instagram
On Wheelwell
Old 11-06-2018, 02:41 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by ern-diz View Post
Soon...sooooon...
I know. This stupid compressor is messing with my fun.
Looking forward to the following on my first drive:
1) smoother, more robust acceleration
2) no clunks, clanks, knocks
3) cruise control testing
Old 11-06-2018, 01:58 PM   #3
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
One thing I will add based on my experience with the auto...
The ECM is adaptive, this means it will build fuel trim maps and shift patterns based on YOUR driving habits.
My wife would drive my car most of the time, so when I got in it the car felt sluggish due to her conservative driving. Once I was able to drive the car a while, the performance feeling returns.
Old 11-06-2018, 02:45 PM   #4
06YarisRS
Ah Ha! Clearly then there is only one acceptable driving style.
I'm more of an accelerate fast, but not burnout kind of guy...at least since getting older. So, say, routinely running up close to redline at WOT off a ramp onto the highway for example shouldn't adversely affect either my engine or trans, then?
Old 11-06-2018, 03:00 PM   #5
ArmstrongRacing
Data doesn't lie
I use WOT regularly as prescribed by my physician
Old 11-06-2018, 06:28 PM   #6
06YarisRS
I'm guessing mine is going to say the same at my next appointment.
Old 11-06-2018, 07:58 PM   #7
06YarisRS
5 minute job removing the a/c compressor. The little plastic panel next to the radiator pops out easily with the removal of two plastic pins and creates a good sized window to the compressor, water pump etc. Excellent design on behalf of Toyota. I still think that changing out a water pump with the 2ZR shoehorned in there will be a royal pain in the butt.
Old 11-07-2018, 01:40 AM   #8
ArmstrongRacing
Data doesn't lie
#7
Old 11-07-2018, 08:57 PM   #9
06YarisRS
First Drive Tonight!
Initial observations:
Much more refined feel. The engine is much smoother and the valve train is almost inaudible.
The car pulls hard right up to about 6000 rpm before it shifts. Does it push you back into your seat? Not exactly, but it's definitely more potent than the 1.5.
It's much more 'torquey', if that's a word.
Shifting is precise.
My little aging Yaris (with 180000 kms) now has an engine with around 70000 kms!
Am I impressed? Damn straight!
Please excuse both the mess and the crappy pic quality.
I have a small exhaust clunk as the muffler, on some bumps and harder cornering is hitting the spring seat, but I think this is a quick fix when I get the exhaust work done. EDIT: The muffler is just turned a bit counterclockwise. My midpipe is in two sections (for shipping, I assume) so I just need to loosen the clamp, level the muffler and retighten. I expect that the new exhaust will allow the engine to breathe a little better. That oem muffler and piping is so tiny.
The 'new' used ac compressor is virtually silent.
As a major bonus, the cruise control is fully functional!
So, to Tom, Trevor, Adam and Sam (not in any particular order), a huge THANKS for helping me through this!!!
Old 11-08-2018, 10:38 AM   #10
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Always glad to help, especially when someone is pioneering a new variant!
Agreed, it's not sports car level acceleration, but it's there all the way to redline. My favorite part is the way it loves to pull several hundred pounds of trailer and a hatch full of tools. =)
Old 11-08-2018, 12:56 PM   #11
06YarisRS
Thanks Sam! One of the things I was looking for in the swap is more torque for highway cruising. I never found the 1.5 to be particularly underpowered, but it would downshift on longer, steeper hills. I haven't actually had it out on the highway yet, so can't comment on that , but your comment about carrying extra mass around makes me optimistic. I do think there is something in the programming for the cruise control that makes the car downshift before it needs to. I have rolled up long hills with the cruise off and rarely had to drop a gear to maintain speed. Something tells me that despite the swap - and extra torque - that this behaviour won't change.
Old 11-07-2018, 10:42 PM   #12
ArmstrongRacing
Data doesn't lie
I’m glad you took on this swap, we all learned something new and you now has a legit RS(nice badge!)
I wish I have a plaque or badge....or anything to give you as a welcome to the 2zr fam.
But sadly I never had anything made
Old 11-07-2018, 11:12 PM   #13
06YarisRS
Thanks Tom! It's so cool. So glad I did the swap. Now...I get to update my sig.
Old 11-08-2018, 08:39 AM   #14
More legit...find yourself a TS badge. Got one in my garage but it's pretty beat up.
Old 11-08-2018, 12:49 PM   #15
06YarisRS
I really like that idea, WeeYari. I think I may start looking. Does that badge go in the same place as the RS badge and would it attach in the same manner?
Old 11-08-2018, 12:56 PM   #16
ArmstrongRacing
Data doesn't lie
Oh right TS. I’m so confused now with all the different home-made versions we’ve created here...
1nz built n/a
1nz supercharged
1nz turbo
1nz with 6 speed
And
2zrfae swap
2zr with auto
2zr with 5 speed
2zr with 6 speed
Old 11-08-2018, 01:07 PM   #17
06YarisRS
Like this?
There is this, but it looks like a peel-and-stick only. I would need one that attaches to the grille.
https://www.ebay.co.uk/p/TRD-T-Sport...p2047675.l2644
Looks like I found the actual badge (Toyota 75301-52010) in the UK, but it will not ship overseas.
Old 11-08-2018, 07:43 PM   #18
tmontague
tmontague's Avatar
Like this?
I have that badge on my trunk, after about a year the red faded and crack/chipped, looks ok but cheap as hell
I initially had a 2.5" and can confirm the loss in torque according to my butt dyno. I went back and got 2.25" and I'm all smiles now
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 09:07 PM
2zr swap and e-test in Ontario tmontague Performance Modifications 7 12-23-2016 09:12 AM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
