I've put these Chinese android units in my last 4 vehicles - ranging from Android 4.41 - Android 6.xx. I put a Chinese WinCE factory fit in my 4th gen. Dodge Grand Caravan. I have had only 1 failure and it was a touchscreen. The replacement screen is around $40.00. All of these units have exceeded my expectations. Western offerings are more expensive and are not factory fit - important to me.
Are the quality of the electronics up to par with a high end Kenwood? Likely not, but uness you're an audiophile, I bet it would be hard to tell the difference. As far as long-term relaibility, I sold my Kia Rondo locally and the head unit is still fully functional. It is at least 3 years old and has survived extremes of temperature. Something else I've found is that these units do work significantly better with a dedicated amp using the low level outputs. OEM radios are tuned for a frequency response that works 'well' with the crappy speakers. You may find your sound a little thinner (less bass). But, using the app mentioned below (PowerAmp) you can use the EQ to tailor your sound. Minimally, I'd replace the door speakers and anything but the cheapest junk will be a significant improvement. Keep in mind that the usually stated 45w x 4 peak power of these headunits is overblown and is probably similar output to your stock radio - maybe 14 - 17 watts RMS/channel. The good: Android OS factory fit plug and play (unless you're installing other gear - amp, speakers, sub etc) incredible versatility (endless apps) Wifi internet excellent customizable audio* (with PowerAmp digital processing App - about $6.00) In my experience, this transforms the sound quality. large external storage (I have around 2000 songs on a 16Gig microSD card - no wires, adapters, plugs to contend with) The Bad: If it breaks - throw away, unless it's something like a touchscreen as above. Slow boot - on the order of 15+ seconds Generally poor radio reception no Sat/HD radio Nothing else comes to mind. At that price, I'd go for it. I considered a unit like that with the side panels and the price you're mentiong is probably the lowest I've seen - especially with 2G of Ram. But you have to be willing to accept that you're out your money as shipping back for repair is prohibitive. Though, if you know a good electronics repair person, you could likely source the parts from the Chinese. I bought all my units on aliexpress with free shipping. Shipping is usually really quick and to your door. Here is a link to my latest install: http://www.yarisworld.com/forums/showthread.php?t=59495
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 09-28-2018 at 05:38 PM. |
| Need opinions on these wheels ASAP! | PumpkinSteve | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 18 | 02-16-2011 02:26 PM |
| Need some new headunit opinions | pvt_melfi13b | In Car Entertainment + Electronics (audio / video / alarm) | 10 | 06-28-2010 06:54 AM |
