Old 10-06-2018, 03:27 AM   #25
stidnam
Drives: Starlet
Originally Posted by eeeeeh View Post
I still can't find the "spare" connectors on neither sides... I've an Australian 2013 Gen3 Yaris albeit the YR spec (lowest). On the driver side I've taken out the small panel (two screws) beneath the knee airbag and looked under, no spare connector. On the passenger side, I've looked around and behind all the existing wires and connectors and didn't find any. Can someone that has that connector take a picture of the actual connector and location of it?
I really don't want to run a wire from the fuse box nor running a wire all the way from the existing dome light down the footwell... :) thanks a lot ppl!
I think you're out of luck mate. I have an 2012 Australian ZR and I couldn't find the connectors. It's also worth noting that we don't even have the panel on the passenger side under the glove box to mount the lamp!
If you really wanted to do it, you'd probably find the necessary wiring on one of the connectors that sit behind the kick panels. You'd need to get testing with a multimeter to see if you can find the ground wire that's being switched and a power source. Good luck :)
stidnam is offline   Reply With Quote
Toyota Yaris Battery Light On - Repair gabo General Yaris / Vitz Discussion 1 08-24-2011 07:21 AM
Yaris AUX (auxillary) Stereo Jack assembly 2008 Yaris omendt Items for Sale by private party 0 07-13-2010 09:46 AM
Help: Water/Moisture Entered Fog Light Assembly bigsky2 DIY / Maintenance / Service 10 12-19-2006 12:10 AM
