Old 10-08-2018, 02:26 PM   #9
B.B._07
Drives: 07 5dr
Originally Posted by miiser View Post
Spark plugs have to change at least every 70.000. And that’s also a high number.
Try to replace those first and if the problem continues then check your fuel pump. It may became weak over the years.
But if you have so old spark plugs, then you may have missfires too
The second gen Yaris uses iridium spark plugs just like almost every car made in the past 15 years which have a very long service life. The recommended service interval for the spark plugs is 120K miles (200K KM) or 144 months.
https://www.toyota.com/t3Portal/docu...MS-08Yaris.pdf
