Old 10-19-2018, 07:49 PM   #11
atomic_hoji
Drives: 2018 Yaris SE 5MT
Originally Posted by 06YarisRS View Post
Hey Adam. I've been popping in and out of your swap thread, and man, I have to say I thoroughly admire your skill, knowledge and tenacity. I'd probably have given up long ago.
lol - I appreciate the compliment, thanks. But then, if I was that clever, I'd have sorted it out by now..
Midpipe and Other Parts
Adam was right. This pipe starts out huge and then tapers down to 1 1/2" after the resonator. It is what it is. Hopefully the flow won't be restricted too much. As much as I hate the thought of it I'm tempted to gut the cats!
That looks (and sound by description) similar to the Walker pipe.. it functions, I just ended up monkey'ing with it more than I wanted to and am not a fan of the sound - but, depending on your preference, it might float your boat. Sounds like the local shop has the potential to do a nice setup for something decent. At least the back-end will be a smexy dual pipe setup.
Quick note (catching up.. lol) re: anti-seize - just remember that torque specs are for clean, dry threads (unless otherwise noted, e.g. cylinder head bolts often list as with oil). When you gob anti-seize all over the threads you're reducing the thread friction, and especially putting a steel bolt into an aluminium block.. I've been fortunate that a little dab and a gentle torque I've never buggered anything up, but I have seen the result and it's no fun to resolve that mess.
Might sound ridiculous and seem obvious, but did you count the ribs on the pulley of the A/C compressor? Guess how I know that when you ask for an A/C compressor for 2ZR and they give you one from a (10th?) gen. Corolla and it doesn't seem to jive that it came from a 2AZ model... ooops.
Looks like you're making awesome progress! Still diving into it this weekend?
-- Adam
atomic_hoji is offline   Reply With Quote
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
How frequently does the automatic transmission fluid need to be changed? Hamster DIY / Maintenance / Service 40 12-15-2018 09:07 PM
2zr swap and e-test in Ontario tmontague Performance Modifications 7 12-23-2016 09:12 AM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
