Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
That looks like the classic plate leak we mentioned, because the engine leans aft a bit when installed all of that leaking oil travels along the head gasket at timing cover seams. Replace the plate gasket and clean it like Trevor mentioned, and you’ll never see another leak.
Sealer squeezed out of that part of the chain cover because it’s a 3-way joint, and the manual requires extra. |
| T Montague's 2zr swap - '08 m/t sedan some extra info | tmontague | Performance Modifications | 285 | 04-20-2021 11:56 AM |
| How frequently does the automatic transmission fluid need to be changed? | Hamster | DIY / Maintenance / Service | 40 | 12-15-2018 09:07 PM |
| 2zr swap and e-test in Ontario | tmontague | Performance Modifications | 7 | 12-23-2016 09:12 AM |
| Problem help | MickZEL | DIY / Maintenance / Service | 38 | 08-01-2011 02:52 PM |
| Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 04:25 PM |
