Old 11-26-2018, 05:04 PM   #19
praivo
Drives: 2000 SCP10, 2001 NCP13
Resurrecting this thread, because I'll soon need to get the engine out of my NCP13 T-Sport in order to replace a part of the passenger-side frame rail and change the main seals and a few other things while I'm there.
My question is, can I also pull it out all at once like that? And if so, what do I need to remove (on the subframe/engine)? I think it's the 4 bolts holding the subframe to the chassis, the bottom of the struts, the exhaust manifold, then any sensors/wires/vacuum lines and it should be free, right?
praivo is offline   Reply With Quote
wtb subframe for an 07 lb marlondog Willing to Buy by private party 2 10-14-2013 02:51 PM
Official: Toyota dropping the Matrix after 2013 (from U.S.) Kal-El Off-topic / Other Cars / Everything else Discussions 10 08-09-2013 08:49 AM
Dropping out of boost/not activating 47_MasoN_47 Forced Induction Forum 13 05-06-2013 05:26 PM
MPG Dropping NRclem Fuel Economy Forum 20 01-07-2013 12:39 PM
need to tighten subframe..? TickleTimeTim DIY / Maintenance / Service 1 06-26-2012 01:55 PM
