Old 12-07-2018, 07:37 AM   #1
tmontague
tmontague's Avatar
Originally Posted by atomic_hoji View Post
For reference / interest, this is the setup I used to the clean the injectors. Installed a piece of tygon hose onto the injector at one end, sprayed carb cleaner fluid into the tygon, then put an air attachment on the other end. Secured with hose clamps. It uses the air to pressurize the setup to 10-15 psi; fuel pressure is ~50psi or so, so no issue for injector, but I didn't trust the hose clamps to go too high.. lol
To fire the injectors I had a couple of wires attached to my 12V powersports battery from my ATV for power (not shown). While I held the injector assembly, I had my wife hold the negative on one terminal and rapidly tap the positive on the other terminal. Did this until the injector was clear of fluid. Carb cleaner stinks - do this in a well ventilated area!
Spray patterns looked decent when we were doing it; because of the tip installed on the injector there are two distinct injection sprays - one to each intake port.
-- Adam
Attachment 60073
Nice set up for the injectors
Tags
2zr, 2zr-fe, 3rd gen, t-sport
Toyota to Debut 2018 Yaris At New York; No Mention of Yaris GRMN Thirty-Nine General Yaris / Vitz Discussion 39 07-01-2017 11:38 PM
Went and looked at a yaris Sport! mr_miles General Yaris / Vitz Discussion 19 02-20-2012 10:28 AM
My UK Yaris T Sport Matty Photo-Video-Media Gallery 9 02-21-2010 07:04 PM
