![]() Drives: 2008 yaris hb Join Date: Dec 2018
2008 yaris starts then dies out in 10-15 seconds
I need help guys. My 2008 yaris hatchback giving me problem. I've been trying to figure it out for about 2 months now and I'm trying to work on it the cheapest way possible. When I start my yaris, it starts then it dies out for about 10-15 seconds. I tried putting different MAP Sensor but it didn't help at all. I end up replacing the 3 yrs old battery because of keep on starting it.
Sent from my SM-N960U using Tapatalk |
![]() Drives: Toyota Yaris RS 2011 (HB) Join Date: Sep 2016
Maybe something blocking your exhaust system?
Why didn't you just charge the battery instead of buying a new one?
I'm not clear in your issue, it starts forb10-15 seconds and then dies. Is this every time and if so does this mean the car will never run or does it start again then runs fine?
![]() ![]() ![]() ![]() Drives: No longer own a yaris :( Join Date: Mar 2012
Could be a fuel pressure issue. Does it keep running if you get on the gas a bit?
I'm a hermit named Lee |
My friend let me borrow his scanner. It came out p0113 intake air temperature sensor input high. I can get it started but only 10-15 seconds even though I press the gas pedal. It sounds like it's choking.
| 2008 Yaris Misfiring Code Issues | TubbusMaximus | DIY / Maintenance / Service | 11 | 04-06-2020 10:23 PM |
| P0705: Yaris 2008 stuck in first gear in D position | eepp | DIY / Maintenance / Service | 3 | 01-22-2018 11:24 AM |
| 5spd 2008 Toyota Yaris trade for auto yaris | tengys | Cars for Sale by private party | 8 | 03-07-2016 05:04 PM |
