Old 12-27-2018, 10:16 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Our local APM auto parts store actually had an A/C schrader valve tool - and this after calling half a dozen shops in the city 80 kms away and no one having one. $6.00 + tax out the door. I'm heading across the border tomorrow to pick up my Denso sensor, 2 cans R134 and the schrader kit.
Current plan is to wait for a warmish day, get my garage up to 65 - 70F, aim my big fan at the condensor and try again. I'll evacuate, replace the o-ring at the expansion valve, the schrader valves and pressure sensor. Then, a lengthy vacuum test. Finally a recharge quantity of R134 (~ 13 oz) and pressure tests based on ambient temps.
From both what Trevor said and what I've read, this is work best not done in winter. I wonder if my vacuum tube would have iced up so badly in warmer weather.
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
A/C Clutch Compressor question tmontague DIY / Maintenance / Service 3 05-11-2014 07:57 AM
A/C Broken On My 2010 5 DR HB ChilliwackGuy DIY / Maintenance / Service 15 07-14-2010 04:33 PM
Easy Defrost A/c running fix billk General Yaris / Vitz Discussion 14 01-16-2009 08:53 PM
