Old 01-01-2019, 08:10 PM   #1
grilled cheeseus
Drives: 2007 3 door 5MT
I built a camping trailer and towed it to Arizona
Sharing this to inspire the curious and refute the naysayers regarding long-distance towing with a Yaris.
I built a camping/travel trailer on a $300 Harbor Freight "super duty folding trailer" frame and drove from NY to AZ over ~2 weeks last fall, about 900 pounds towed, zero issues with my '07 hatchback (on its third cross-continent trip).
Yes, it's slow going over 6000 foot mountain passes, but the roads are full of vehicles with a worse power/weight ratio (e.g. semi trucks), and they do just fine too.
Blog post about the trailer (written before the trip):
https://blog.c-mart.in/posts/hazard-...travel-trailer
Photo album of the trailer build last Spring:
https://imgur.com/a/3hfjtIH
Some things I've done to my Yaris:
  • Curt 11050 "hidden-style" hitch bolted to the recovery points
  • Curt 45028 ball mount with 4 5/8" rise (very recommended to lift your ball)
  • Firestone 4136 air spring kit (very recommended, eliminates saggy rear, easy to install)
  • This trailer wiring harness kit, spliced into the rear brakes and turn signals
  • 5000 lumen light bar from Walmart (stupid and unnecessary, therefore necessary)
  • Junkyard alloy rims from a Chevy Aveo (same as above)
Some shots of the trip to Arizona..
Random pee break:
If this is OK, then towing 900 pounds with a Yaris is definitely OK:
If this is OK (yes they are all connected) then what I'm doing is definitely OK:
Sleeping at a rest stop:
Stayed in St. Louis for a week to attend a conference. The motel let me to park next to the front office for security:
Spent a few days in Tulsa OK to help some people from the internet build a boat:
They taught me to weld, so I disabled the "tilt bed" feature on the trailer frame. Taking this slop out of the trailer tongue made the entire ride less jouncy:
Somewhere in New Mexico:
Final sleep on the road, I-10 in SE Arizona:
Rolling into Tucson (destination and where I am currently):
I've been living out of the trailer (in a friend's backyard) since October. I doubled the electrical system capacity (another AGM battery and solar panel) to take advantage of the Arizona sun and charge my Onewheel (which I use to commute to work).
Later this spring I'll de-snowbird back to NY, probably via the Pacific Northwest.
grilled cheeseus is offline   Reply With Quote
Old 01-01-2019, 09:10 PM   #2
dogsridewith
Drives: 2007 2-door hatchback
Nice!
What were your typical highway cruise speed and mpg?
Old 01-01-2019, 09:26 PM   #3
suprf1y
suprf1y's Avatar
Drives: 05 Echo
Nice job!
I considered doing the same with my Wife's Sonic and spent a fair bit of time researching it on tnttt but we've decided to go in another direction and build a minivan camper instead
suprf1y is offline   Reply With Quote
Old 01-01-2019, 09:30 PM   #4
grilled cheeseus
Originally Posted by dogsridewith View Post
Nice!
Typically about 60 MPH. 65 was still fairly comfortable but I was in no rush and wanted to burn fewer dinosaur squeezings.
I think the best tank was about 32 MPG (in Ohio?) and the worst was about 27 MPG (big headwind in New Mexico). I probably averaged about 29-30.
Old 01-01-2019, 10:11 PM   #5
kimona
kimona's Avatar
Drives: 2014 White VITZ
Very nice setup!
Old 01-01-2019, 10:24 PM   #6
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
So cool!
Old 01-02-2019, 07:31 AM   #7
dogsridewith
Roughly, w/ a tape--what is outside-of-tread to outside-of-tread for both car and trailer?
Old 01-02-2019, 08:00 AM   #8
Leegamer
Leegamer's Avatar
That's awesome.
I'm a hermit named Lee
Old 01-02-2019, 10:28 AM   #9
justanotherdrunk
justanotherdrunk's Avatar
Drives: 2016 SE
looks good thanks for posting
justanotherdrunk is online now   Reply With Quote
Old 01-02-2019, 03:15 PM   #10
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Awesome work!
Old 01-03-2019, 10:25 AM   #11
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
I always get a kick out of this kind of thing. Thanks for sharing.
On Instagram
On Wheelwell
Old 01-03-2019, 12:22 PM   #12
Janviernes
Drives: 06 5door
Awesome work! I think I'm going to switch up my project to a foamie as well.
Janviernes is offline   Reply With Quote
Old 01-03-2019, 07:37 PM   #13
nemelek
DWEED
nemelek's Avatar
Thanks for posting. Love it.
Old 01-10-2019, 04:29 PM   #14
grilled cheeseus
Thanks everyone!
To be clear, mine is not a foamie :) It's 3/4" plywood (except the roof which is 1/2" plywood over 2x3 spars) skinned with sheet aluminum. It's not the lightest way to build one of these, but it is easier to build than foam, and extremely sturdy. I hang 40 pounds of AGM batteries and a 30 pound electric skateboard from the interior walls. Walk on the roof without hesitation.
Honestly, after 3 months of living out of it (and relying on friend's bathroom/kitchen), it's getting somewhat cramped. I'm planning to upgrade to a Class A motorhome (probably 30-35 feet), so my house will tow the Yaris rather than the other way around. I guess it's true what they say about new RVers upgrading to something else within a year.
Old 01-10-2019, 08:22 PM   #15
dogsridewith
Done right, a second tow hook mount installed opposite the existing one might make a good attachment for a fork-type tow bar?
Old 01-16-2019, 10:51 PM   #16
Hamster
Hamster's Avatar
Drives: 2009 5-Door Liftback
That is super cool! Please share more road trip pics if you have any!
Hamster is offline   Reply With Quote
Old 01-22-2019, 04:17 AM   #17
bentjazz
Drives: 2009 Yaris--3dr MT
Wow. Ultra-cool. Thanks for posting. Would like to see what it's like inside the camper.....
bentjazz is offline   Reply With Quote
Old 01-22-2019, 08:30 AM   #18
zoidberg444
zoidberg444's Avatar
DUDE.
I SAW YOU ON SV SEEKER's CHANNEL ON YOUTUBE!
Nice work. I couldn't believe it. I take it your car is the 1NZ engine? I had a feeling it would do fine towing a small trailer. I have loaded my 1L up with hundreds of kilos and driven it up and down mountains for a couple weeks. These cars are tanks.
UK to Nordkapp in a Yaris
towing, trailer
Driving w/ Trailer Safety Connoisseur_of_fine_cars General Yaris / Vitz Discussion 2 11-03-2011 06:00 PM
