Old 01-10-2019, 10:52 AM   #8
Billiam
Drives: '10 White Yaris 4D LB
I bet that yours needs to see the transition from 12V to ground as opposed to floating to ground. In that case, you'd need a single pole dual throw switch to switch between +12 and ground.
As for the ebrake wire, instead of popping the center console to get at the connector, you can tap the other end of the wire at the under-dash fuse panel (behind the change cup by the driver's left knee). It's the yellow wire in pin 2 of connector 4C:
Attachment 42888
Figured I would revive this old thread. I'm getting ready to install a JVC head unit in my daughter's '10 Yaris. I DO NOT want her to have access to the DVD function while driving. So I will be hooking up the parking brake sensor wire the correct way.
So Scott...my question for you is...this yellow wire...is that a negative signal? The installation instructions only say to connect to the parking brake sensor. They don't mention whether that needs to be a positive or negative. Looks like the majority of head units require a ground. I'm guessing the yellow wire is negative when the parking brake is engaged
I plan to check it. But just thought I would ask you as well. Thanks
If you want to enjoy your car, stay off of the internet.
ACRONYM thread Shroomster Off-topic / Other Cars / Everything else Discussions 45 02-15-2025 10:30 PM
Yaris Sedan Deadening and Sound system upgrade derickveliz2 In Car Entertainment + Electronics (audio / video / alarm) 2992 11-18-2021 02:14 AM
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 01:15 AM
DIY For radios that require attaching a wire to parking brake Slick DIY / Maintenance / Service 0 04-16-2009 08:14 PM
