Old 01-26-2019, 08:15 PM   #1
Maritime
Drives: 2008 yaris 5dr hatch
Got grinder to work. This much so far. I think it will be plenty strong. Working out how to gain the 1.5" needed under the mount.
Sent from my moto e5 play using Tapatalk
Maritime is offline   Reply With Quote
Old 01-26-2019, 09:28 PM   #2
Maritime
Ok. This is a start. I can do 2 of these. There is 1.5" between the 2 spring perches so now just need something as the meat in the sandwhich.
Old 01-27-2019, 08:35 AM   #3
myfirstyota
3 Yaris and counting..
You might be on to something there sir
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
Old 01-27-2019, 01:37 PM   #4
Maritime
Trip to ct and found this in the boat.section. high density boat roller. Uv and salt resistant and can carry a huge boat on it.
Cut an inch and half slice and Roberts your mothers brother.
Old 01-27-2019, 01:38 PM   #5
Maritime
Pretty sure it will work fine. Replicate one more and buy the rear spring.spacers and the lift part will be sorted
Old 01-27-2019, 03:35 PM   #6
myfirstyota
I'm really hoping I can get to my metal place this week to pick up my bits!
Let us know when you install these. Dying to find out how it works.
Old 01-27-2019, 04:26 PM   #7
Maritime
Will do. Gonna order the rear spacers tonight or tomorrow and will put it all in once they arrive.
Old 01-28-2019, 10:01 AM   #8
Maritime
So I just pulled the trigger on these, $22CAD shipped off amazon. 1.5" coil spacers. not vehicle specific so hope they fit. Also a set of camber bolts as going up 1.5" will require an alignment I bet.
Old 01-29-2019, 11:41 AM   #9
myfirstyota
Sweet, hopefully Amazon is quick out that way lol
We got a record snowfall for Toronto yesterday. 26+ cm. With just the xd springs and the tires I'm running... this car was unstoppable. I was bombing around stuck SUVs, CUV's and just about everything else on the road. Even 2' snow berms left by the plow were no problem with a bit of momentum. Im guessing 1.5-2" of lift plus a larger tire will satisfy most people's desire for easier mobility in snow.
Old 01-29-2019, 12:08 PM   #10
Maritime
I saw the snow on the news. We're getting that storm here but only calling for 10-15cm. I know with some clearance the little red car will get through anything. The only time I get stuck is when the bottom hits snow and lifts the tires off the ground. Bits should arrive on Friday, I have to do a bathroom reno so we'll see if I get some time to install the lift.
Old 01-30-2019, 12:17 PM   #11
Maritime
Was perusing the web for roof rack options then remembered I have a Thule setup from my old X-Trail(POS) so I am going to see if I can line that up and mount. Anyone know if the spot under the black rubber is thick enough to drill and tap threads? Generally that's the strongest part of the roof.
Old 01-30-2019, 12:48 PM   #12
http://www.yarisworld.com/forums/showthread.php?t=29812
Old 01-30-2019, 12:51 PM   #13
Maritime
Thanks. I found that right after I typed the question. first time I searched I had a typo and nothing came up LOL. I need to look into the expanding anchors from that thread.
Old 01-31-2019, 01:05 PM   #14
Maritime
Rear spacers are supposed to arrive by tomorrow, Amazon guarantee. Camber bolts are landing in Maine today along with some other bits and bobs I ordered. Hopefully this weekend I can get the lift in, and get the rack out of storage and get it on too. I think I am going to wrap one of my wheels/tires with some foam or cardboard or something to add the width and diameter of the new tires and mount it up into the wheel wells front and back and see if anything is going to rub etc. That way if I need a spacer I can order them before I order the tires.
Old 01-31-2019, 01:09 PM   #15
Leegamer
Leegamer's Avatar
Drives: No longer own a yaris :(
I'm hoping you will take pics to document!
I'm a hermit named Lee
Leegamer is offline   Reply With Quote
Old 01-31-2019, 01:11 PM   #16
Maritime
Yeah I will, I just noticed the links to the pics of all the parts I did are not showing in the thread anymore?
Old 01-31-2019, 01:14 PM   #17
Maritime
Just on my work pc, fine on phone. Looks like our new office 360 is blocking stuff
Old 02-01-2019, 05:16 PM   #18
myfirstyota
I think you'll have to make rear axle drop brackets if you don't want the angle of the axle affected. I plan on a 3-4" lift and I'm just gonna push that axle down. It will be way too much fab work to make axle mount drop brackets. I took a quick look one day to see if some sort of bolt in drop brackets could be made. Didn't look remotely easy to me.
Praying I can get my spacer bits next week. Didn't have time to get to the metal place before 5 this week :(
Vacationed in Italy - Brought home a D4D diesel Yaris CTScott Photo-Video-Media Gallery 19 07-26-2012 03:13 AM
