Old 01-21-2019, 02:37 PM   #1
ojeysky
Drives: Sedan Yaris 2010
I am using a 2010 Yaris and the best I could get from a 35litre is 245miles. Is this a normal fuel utility or should I be worried?
ojeysky is offline   Reply With Quote
Old 01-23-2019, 02:00 AM   #2
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Mixed metric and imperial units, but it seems rather poor. That works out to roughly 8.9 litres per hundred km. Is this heavy city traffic?
Old 03-24-2019, 05:43 PM   #3
ojeysky
Sorry for coming back late on this, not so much heavy city traffic just normal city driving. I was formerly using conventional oil, I switched to synthetic though I get much quiet engine it didn't improve my milage much.
What could be the problem?
Thanks
PS: No check engine light
Old 03-25-2019, 03:23 AM   #4
rayfloyd170
Drives: Yaris 2016 1.3 Manual
Thanks
Whats your odometer reading now and when was you last preventive maintenance?
mine was about the same as yours at 75k KM then i changed spark plugs, cleaned the throttle body and MAF sensor and replaced the engine air filter during the lube oil change (synthetic all the time).
It made a big difference and the engine is now more economical and powerful than before. Currently at 35.2 - 37.6MPG whereas before it was around 29.4MPG
rayfloyd170 is offline   Reply With Quote
Old 09-07-2019, 10:11 PM   #5
carstudiopk
Drives: Toyota Belta 1.3, 2008, 3SZFE
Also, clean the MAF sensor. You'll love the result
Sent from my vivo 1727 using Tapatalk
carstudiopk is offline   Reply With Quote
Old 09-07-2019, 10:10 PM   #6
carstudiopk
Check the fuel tank capacity again. I believe it is 42 litres
My progression into hypermiling BailOut General Yaris / Vitz Discussion 8 10-13-2009 07:31 PM
Yaris Mpg query Vanguard General Yaris / Vitz Discussion 3 03-18-2007 10:56 AM
