![]() Drives: 2007 Toyota Yaris Join Date: Feb 2019
07 Yaris Auto. ABS & Brake light staying on.
Hello everyone!
First post here. I have a 2007 Toyota Yaris Automatic. My ABS and Brake Lights are constantly staying on. They turn off for a little bit but they constantly staying on for the most part. I took it to a local shop and they are saying to replace both rear wheel bearings. Just wondering if anyone else has any experience with this? I bought my yaris in August with 110k miles and now its at 120k. |
Lots of mammoth historical threads on this issue. Known problem with corrosion occuring in the rear abs connectors. There are tips on attempting to clean them yourself.
Sent from my EML-L09 using Tapatalk
Put the following in the search box
ABS and "!" lights are ON again! Sent from my EML-L09 using Tapatalk
What brand Wheel Bearings are the most reliable and cost effective? Moog?
So I searched the forum. Seems like people are saying to replace the wheel bearing hub (which has the abs sensor attached to it). or theres another sensor that attaches to the wheel bearing hub? Can someone clarify which parts I should look at and replace?
The threads describe procedures for disconnecting, cleaning, packing with dielectric grease and reconnecting the rear hub sensor connectors. This often solves the issue.
#8 | |
I am going to show it to a different mechanic today or tomorrow so just want to get some knowledge about the issue. |
#9 | |
Sent from my CLT-L04 using Tapatalk |
![]() ![]() ![]() Drives: Yaris 06 - 5dr hatchback Join Date: Aug 2015
I had this exact problem on my car last winter. I just gave the connectors a clean when i did my spring service and it has been fine.
![]() - Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles UK to Nordkapp in a Yaris
| Noise From ABS when Braking + ABS & (!) Light On - Please Help | Chris Jackson | DIY / Maintenance / Service | 2 | 04-23-2016 12:00 AM |
| Yaris 2007 ABS & Brake light issue after wheel bearing change | DevilzMafia | DIY / Maintenance / Service | 4 | 01-17-2013 09:24 PM |
| Toyota Yaris -06 VCC and ABS light went on? | goedafred | DIY / Maintenance / Service | 4 | 03-01-2011 12:22 AM |
