Old 10-08-2019, 08:31 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Oof, I'm not sure I'm knowledgeable enough to answer you there... From what I gather, with premium fuel and not such a huge amount of boost, you should be OK... You have the advantage of not living in the hot, humid tropics too :D Does your engine have a knock sensor? If so, there should already be some mitigation built-in.
Yes, there are many variables to consider and every car, and every engine is different. I'm pretty sure I'm safe with 93 octane, low boost and cool charge temps. I rarely have to enter boost under normal driving conditions. I can easily sail up a long highway hill at 130 - 140km/h while still in vacuum. When I want full boost (which is now 6 - 6.5 after adjusting the wastegate eariler today) I go WOT and my mixtures are good and rich. My car does have a knock sensor, as far as I know.
Old 10-06-2019, 10:22 PM   #2
06YarisRS
Milk run tonight...
Here's a terrible quality video. I'll make a better one in the daytime. Max boost reached was ~5.5, so gotta get at the wastegate, plus lean up my AFRs at WOT. It is definitely a "safe" tune at WOT at around 10.5:1, so that could probably be leaned out a touch, like around 11.5, but I'll leave it as is for now, at least until I up my boost.
Anyway, it pulls hard and puts you back in your seat a bit. If I do mange to get up to 7 - 8 psi, it will be scary. Even now, I can't go WOT until about 30 - 40 km/h or the wheels will spin. It breaks loose in the video at around 50 km/h even if I ease into the throttle.
There's definitely more room for improvement, but it's a blast right now as it is. No WRX killer for sure, but if I get to my boost goal, I bet I would at least not totally embarrass myself.
https://www.youtube.com/watch?v=31SC...OId1fR8gZcZNvs
Old 10-09-2019, 04:40 PM   #3
06YarisRS
Adjusted wastegate yesterday. I gave the arm 2 turns. Boost is now steady 6 - 6.5 psi. At one point coming off a ramp on to the highway, I hit 7 psi. I'm going to give the wastegate another turn tomorrow. If I reach 7 - 7.5 psi, I will stop there. Soon I will do another video, but in the day this time since the night one turned out so crappy.
Old 10-28-2019, 06:08 PM   #4
06YarisRS
8 psi!
I adjusted the wastegate again about two days ago and hadn't driven the car until today. There is a significant difference between 6 and 8 psi. Although the car pulled hard at 6, it's absolutely insane at 8 psi. Torque steer is becoming more apparent, but the car is easily controllable with a good drip on the wheel. Truthfully, I don't think I really understood how much of a difference preloading the wastegate could make. When I clocked the turbo, I had to remove the actuator, actuator arm extension and the actuator bracket. When I put it all back together, I don't think that I had shortened the arm to the preset length. I was a bit long. This was causing the wastegate to open quite a bit around 5 psi.
I'm definitely looking more seriously at performance tires. I think I will go with either a 195/55R15 or might press it a bit and go for a 205/50/15. I've been doing a lot of reading and although 205 is well out of spec for a 5.5" rim, a lot of guys have been using this size tire with that rim width. Some day I'll buy new wheels for the car as much as I'd hate to change the stock look. I have been pushing the 195s I have on the car quite a bit harder than my normal driving and I'm not noticing any performance issues, no sidewall roll or the like and that's with about the cheapest tires you could buy in that size. A performance tire with a stiffer side wall might allow me to go with the wider 205 tires. I also think that would enhance the look of the car significantly.
I'm still mulling over which performance brake pads to buy. The Hawks are currently at the top of my list. Also exploring the rotor options available for the car. I'm open to any opinions regarding rotors, slotted, slotted/drilled, drilled, blank and midrange pricing.
Old 10-29-2019, 04:31 PM   #5
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
More awesome news!!
Just be aware though, high performance summer tires lose grip at low temperatures, making them really unsafe. I haven't looked at high performance all seasons yet but that's a possibility.
Old 10-29-2019, 04:54 PM   #6
Leegamer
Leegamer's Avatar
Ok, so now that you're used to 8 PSI when is the built motor going in and getting fed 30 psi?
Seriously though, congrats...that's awesome that you're now beyond the limits of your tires and brakes now.
I'm a hermit named Lee
Old 10-29-2019, 06:16 PM   #7
06YarisRS
Haha, my thoughts exactly about an engine build! Not likely to happen anytime soon, but not out of the question either. Of course, then I'd definitely have to do something about my other drivetrain components.
With respect to being beyond the limits of my tires and brakes, the stock setup is quite acceptable, but the quick acceleration is making me want to push the car always harder on the windy roads around here. I just feel that before long, I am going to reach their limits. I'm not exactly sure where those limits are, but I know that I want to exceed them.
Old 10-29-2019, 06:06 PM   #8
06YarisRS
Originally Posted by CrankyOldMan View Post
More awesome news!!
I hadn't thought about that, Sam. Where I live it's always cooler than the surrounding areas as we're on the ocean. I also do a lot of driving in the fall, right up until the first snowfall. Maybe I really ought to be looking at performance all-season tire. Truthfully, I'm finding the current tires quite satisfactory but I'm really not pushing them to their limits. I'd be appreciative if you could make a suggestion of a brand of performance all- season tires that you feel would be good for all around handling, but that might be slightly more capable than a typical inexpensive tire. This of course, if you do investigate them for yourself. I did have a look at the Toyo Proxes TR1 tires in the 195/45R15 size. They look nice and can be had for a very good price
Old 11-04-2019, 10:06 PM   #9
tmontague
tmontague's Avatar
for your climate and how long you drive the car into the fall season I would recommend Continental Extreme Contact DWS. They are not the most performance oriented but it will allow you to get as much use out of them in a single year than any other performance oriented tire. FWIW the BFG sport comp 2's I have allegedly do well in cold temps as long as it isn't ice. I have never and will never test this out however. BFG does sell an a/s version of the sport comp 2's that are meant as a performance all season. They would be a competitor to the Conti's and both tires have great reviews.
A tire like the TR1 is likely more tire then you need or could really take advantage of at this point based on what you have said so far. It also won't let you drive your car as much throughout the year. A slightly less sticky tire will typically squeal earlier letting you know when you are close to its limits where as a more performance oriented tire squeal happens when you are virtually at the end of the limit and sometimes it is too late to catch if you are not experienced enough to catch it before it is too late.
Old 11-05-2019, 03:33 PM   #10
06YarisRS
Excellent info, Trevor. Yeah, I'm definitely looking for a balance of handling and ride quality. I don't think I need an extreme handling tire. The BFG Sport Com 2s do seem to come in a 15" size. Also seems to be the case for the Contis.
What are your thoughts on these tires? Nankang NS-25 All Season UHP in 205/55R15
https://www.ebay.com/itm/4-New-Nanka...5308e659d21418
Here is some feedback on the tires:
https://simpletire.com/Reviews/items...all-season-uhp
Old 11-03-2019, 05:07 PM   #11
06YarisRS
Extra Plugs
I picked up two sets of SC20HR11 plugs. I scored them for ~$13.00 a set. Since the SC16HR11 plugs are the OEM plug, I'm gonna just call the 20s 'one step colder', gap them to 0.28 and use them. I hope to pull my current plugs this week and have a look at them. They've been in the car for probably 8 - 10 thousand kms as I replaced them before I did the engine swap. They probably have 1000 -1500 kms on them since the turbo install.
Old 11-07-2019, 06:24 AM   #12
06YarisRS
Street Tuning
Well, more like highway tuning. I had been noticing that my AFRs were starting to lean out slightly under hard acceleration on the highway from about 100 km/h up. The car would start to lean to ~ 12.8:1 - 13.00:1 and then it would drop to 11.5 as WOT continued. Last night I brought my laptop on our short trip. My son had it on his lap and I had him tweak the fuel cells by adding fuel in the lean areas. We spent about 20 minutes under different WOT speeds and smoothed the map out. There's still a bit to do, but the leanest we saw under full throttle through the rev range was 12.0:1. He really enjoyed doing this. I was proud of my little man.
Old 11-07-2019, 11:37 AM   #13
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Street Tuning
Nice!
On Instagram
On Wheelwell
Old 11-07-2019, 11:50 AM   #14
Leegamer
Leegamer's Avatar
That's cool! Father-Son bonding FTW
Old 11-07-2019, 10:10 PM   #15
06YarisRS
Yeah, gents, he really enjoyed it. I had colleague/buddy who's also a car enthusiast lined up to help me tune. I thought I'd see if my 10 year old wanted to give it a try and he jumped at the opportunity. It also helped that it involves a computer as he's majorly into those too.
Old 11-08-2019, 08:20 AM   #16
Leegamer
Leegamer's Avatar
Show him some PFI Tuning videos on youtube, maybe he'll be the next big tuner! lol
Old 11-08-2019, 10:56 AM   #17
06YarisRS
I definitely will. You've got me intrigued too.
Old 11-10-2019, 08:41 PM   #18
06YarisRS
Merging onto the highway. Had a great time with the car today. I'm thinking I'll order a gopro or similar camera so I can actually make a decent video.
https://m.youtube.com/watch?v=80WPr7khL9k
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 04:59 AM
Hyundai Turbo Veloster 150kw *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 01-09-2012 11:35 PM
ZPI Turbo for one lucky Yaris owner..... ZPIracing Forced Induction Forum 27 04-26-2007 10:36 PM
