Old 03-16-2019, 06:23 PM   #11
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Proposed Wiring for the F/IC
I used the engine control diagrams I got from TIS for the 2008 Scion xD. Also attached is a pic of the 2ZR Engine Control I found online and a link to the F/IC wiring diagram. Please chime in if you see anything amiss or have suggestions. I will add the diagrams for the power supply and ground for the F/IC later.
Interestingly, the tuner with whom I was speaking said that it would be unnecessary for the F/IC to control camshaft timing and that the stock ECU would control that. He seems very knowledgeable, but this just seemed odd to me. I suppose though if it is true and the F/IC is not controlling timing, that the crank would not need to be connected either.
AEM F/IC Manual:
https://www.jegs.com/InstallationIns...17-30-1913.pdf
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 04:59 AM
Hyundai Turbo Veloster 150kw *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 01-09-2012 11:35 PM
ZPI Turbo for one lucky Yaris owner..... ZPIracing Forced Induction Forum 27 04-26-2007 10:36 PM
