Old 03-17-2019, 02:57 PM   #11
Saintjmv04
Drives: 2019 Toyota Yaris
Dual system for Direct injection, 4.5/5 JD Power Reliability Rating
This engine has direct injection, which can carbon up the intake valves. Also Mazda automatic transmissions are not as good as the Asin transmissions Toyota uses. You’re probably get good use out of the car, but it’s not a Toyota!
First off, you are partially correct regarding the direct injection system. It is a dual system... there are two injectors per cylinder, one above the valve and one directly in the cylinder. This design prevents carbon build up.
Also, the most recent Yaris Sedan based off the Mazda 2 platform is rated by JD Powers as a 4.5/5 star rating for reliability... I could argue other things, but this is just to touch the surface.
The yaris is an incredible value for what you get in terms of fit, finish, solid aftermarket support, fuel economy and descent engine power for day to day driving for those of us that don't race around trying to pass every car we can on the highway.
Saintjmv04 is offline   Reply With Quote
Spyder Auto 06-08 Toyota Yaris Sedan Headlight/TailLights FREE set in SoCal!!! rmota83 California 14 03-24-2013 04:41 PM
yaris Advance Sedan Rudeshady Central and South America 14 06-25-2007 01:50 AM
Official Toyota Thailand accessories for Yaris Hatch & Sedan eTiMaGo Cosmetic Modifications (Exterior/Interior) 85 04-18-2007 07:53 AM
