![]() ![]() Drives: 05 Echo Join Date: Jul 2009
#2 | |
It's your call on pads and how long/well they hold up entirely depends on your tires and even more importantly, how hard you want to brake in the braking zones. My first 2 track days were on old race slicks and Hawk HPS pads (performance street). I thought they were fine until the next season when I started working on late braking and glazed over 2 sets of pads rendering them downright scary and useless. I now use a track pad (Carbotech xp-10) but they are not really that great on the street as they have poor stopping power when cold. Hawk Blue's as Ron stated will likely be more than adequate, or a Carbotech pad that is less aggressive like an AX-6. I use brake fluid from Canadian tire, the OEM brand makes a "performance" DOT 3 which has a dry boiling point just under 500F. I have never had an issue with fluid even when my rotors started turning blue, I just bleed the fluid every couple track days. That fluid is about $19 per liter vs around double the price for something like Motul 600 fluid. Yaris' are light cars and are not overly hard on brakes but TPM is a tight track with a lot of hard braking. Just double check all of the maintenance things like fluids and make sure your radiator is clean/clear of crap. It's a great way to get out frustration, learn how to be a better driver and have fun in a safe environment. Oh and the Yaris group is a good bunch of people which makes it that much better.
| 06YarisRS's 2ZR-FE Swap 5-Door Hatchback (Automatic Transmission) | 06YarisRS | Performance Modifications | 448 | 12-06-2018 09:12 PM |
| Toyota echo engine swap confirmation | Brick | DIY / Maintenance / Service | 5 | 11-02-2018 06:45 PM |
| 2001 Echo cluster swap, HELP | VitzAus | General Yaris / Vitz Discussion | 1 | 02-05-2017 02:38 AM |
| Problem help | MickZEL | DIY / Maintenance / Service | 38 | 08-01-2011 03:52 PM |
