Old 03-31-2019, 12:20 AM   #1
tmontague
tmontague's Avatar
Your stock manifold looks a lot different than mine. I noticed mine looks like a typical aftermarket welded and bent tube design whereas yours appeals to looks like a cast design. I would have assumed they would he the exact same.
Btw great job so far and I appreciate you taking pics of everything
Old 03-31-2019, 01:02 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Thanks, Trevor. Pretty sure mine is welded tubing, though it does look cast in the pics.
I was hefting the turbo tonight and it's quite a heavy beast. The manifold, as you know has 2 studs/nuts up top and 3 below. I don't quite understand this as the reverse would be more structurally sound, IMO. I'm going to see how difficult it might be to adapt the existing manifold support bracket to work with the turbo. There are 6 bolts on the compressor housing and 4 on the turbine. If it works in a way that the turbo downpipe clears the stock support bracket, I may see if I can bolt a support arm from the stock bracket to the turbo using either the compressor or turbine bolts - which ever is more centered over the support. I know the turbokits guys knew what they were doing when they built the kit, but it just seems like a lot of mass hanging from that manifold. The manifold itself could probably hold a ton (not exaggerating) but I'm a concerned about the 5 fairly small studs/nuts that hold it on. If the Toyota engineers thought that the small lightweight manifold needed a support, then I'm thinking that this turbo is a heck of a lot heavier and could use some support. Maybe I'm overthinking this.
Old 03-31-2019, 06:11 AM   #3
myfirstyota
3 Yaris and counting..
..... I know the turbokits guys knew what they were doing when they built the kit, but it just seems like a lot of mass hanging from that manifold. The manifold itself could probably hold a ton (not exaggerating) but I'm a concerned about the 5 fairly small studs/nuts that hold it on. If the Toyota engineers thought that the small lightweight manifold needed a support, then I'm thinking that this turbo is a heck of a lot heavier and could use some support. Maybe I'm overthinking this.
I wouldn't say so..brace that puppy as best you can.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 05:59 AM
Hyundai Turbo Veloster 150kw *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 01-10-2012 12:35 AM
ZPI Turbo for one lucky Yaris owner..... ZPIracing Forced Induction Forum 27 04-26-2007 11:36 PM
