Old 06-10-2019, 08:55 AM   #11
heeroyuy01195
Post count means nothing.
Sounds like you had a blast, lots of good info here!
That does wound a bit odd with the oil temps. Not sure if this applies to the 2zr but I know with the 4ages we have oil starvation problems when it's being pushed hard and/or during repeated hard cornering. We combat this with running a baffle in the oil pan or if you're truly dedicated, going with a dry sump setup. It's been a little while since I've worked on my MR2 or done much reading on the 4age so take that with a grain of salt. Anywho, perhaps it's similar with the 2zr?
Need 07 Sedan Tail Light wiring info ASAP atebit General Yaris / Vitz Discussion 3 09-07-2013 06:48 PM
Swap sedan tach into liftback GrassrootsMS DIY / Maintenance / Service 17 09-26-2007 09:45 AM
thinking about buying the sedan. is it worth the extra money for the s(optB) version? friedbbq General Yaris / Vitz Discussion 14 05-20-2006 12:53 PM
