Old 10-25-2019, 10:38 PM   #1
alec801
Drives: aw11, ep91, ncp91
Radiator fans only come on with red light
I've got a 2006 yaris.
Would anybody have any ideas as to why my radiator fans won't turn on until the red overheating light comes on?
I can see the temp go up to 80-90°C where the fans used to turn on but they won't come on anymore.
I have replaced thermostat, coolant temp sensor, fan relay 02, checked a few related fuses but figure out what is going on.
any ideas?
alec801 is offline   Reply With Quote
Old 10-26-2019, 12:16 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Water pump? Breaks in wiring/grounds? All connectors are seated properly? The fan itself? Maybe try applying a direct 12v to the fan and seee if it works.
Tags
coolant, cooling, overheat, radiator
Do you feel ur Yaris shaking when waiting at red light? Yawesh DIY / Maintenance / Service 59 02-06-2019 07:14 AM
Unexpected Seat Belt Light Flashing ern-diz DIY / Maintenance / Service 19 09-23-2018 02:03 AM
SRS warning light, pass. seatbelt light, pass. airbag light PROBLEMS! tylerwatts53 DIY / Maintenance / Service 1 07-17-2014 09:53 AM
red light camera intersections in CA omgamihealthy Off-topic / Other Cars / Everything else Discussions 4 04-10-2011 02:08 PM
Matching Painted Tail Lights dg4rez Items for Sale by private party 21 12-30-2009 10:07 PM
