Old 04-14-2020, 07:37 AM   #1
hello123
Drives: Toyota Yaris YRS 2012
P0011 fault code regularly
Hi all
I own a 2012 automatic Yaris and for the most part of 1.5 years my car has been dying while driving and showing the check engine light and traction control. It happens once about every 6-8 weeks, and when I turn the car off and on it seems to run fine after that.
I’ve had it in 3 workshops and the fault code P0011 always comes up and I’ve been told to just continue driving. One place has offered a complete engine rebuild, which I’m not keen on because the car has done nearly 200 thousand already. I’m also female and feel intimated by the mechanics and salespersons, so I’m not sure what to do. Has anyone had the problem before and can give me some confidence on what to discuss with the mechanics to hopefully just show that I somewhat know what I’m talking about and can hopefully not get ripped off?
Thanks!
hello123 is offline   Reply With Quote
Old 04-15-2020, 06:12 PM   #2
have you tried a new (intake) cam sensor? its an easy DIY in your driveway...
Old 04-16-2020, 08:06 AM   #3
remcafee
Sounds like vvti solenoid or vvti can gear could be on its way out. You should really take it to the dealer for a proper diagnosis and determine if you want them to repair it or look around cheaper else where
Old 04-17-2020, 09:12 AM   #4
Vvt solenoid is also an easy DIY
2012, p0011, yrs
Fault code P2196 Oxygen sensor? Saphe DIY / Maintenance / Service 9 12-16-2021 08:07 AM
SRS B1653 fault code CB900F2 DIY / Maintenance / Service 3 11-14-2018 08:33 AM
The Official "Bamboo the Yarisworld Traveler" Thread (v4, part 2) Darb Off-topic / Other Cars / Everything else Discussions 86 10-18-2017 08:03 AM
full tank japle Fuel Economy Forum 15 12-10-2013 11:05 AM
Anybody know the code? Driver New YARIS Purchase Forum 5 08-20-2006 06:56 PM
