Old 04-22-2020, 11:30 AM   #10
Zedicus
Drives: scion xb
the prius C engine is the one to use to make any substantial 'gains'. the original prius 1.5l engine is basically identical internal except for pistons. you can swap pistons to the yaris 1.5l, or swap yaris cams to the original prius engine.
the prius c engine has newer designs on some of the problematic 1nz issues (valve stem seals come to mind) but it requires 'some work' to install.
i have a write up on an install in a 1st gen scion XB, i will post some.
Zedicus is offline   Reply With Quote
forged 1nz turbo build 1nz_tommy Performance Modifications 2 10-22-2014 08:40 AM
1NZ / 2NZ Transmission Compatibility & Aftermarket 2NZ Rods jtw11 Performance Modifications 8 09-03-2013 01:49 PM
Forged Pistons, connecting rods, piston rings etcetc mastaofdisasta Performance Modifications 2 04-18-2010 12:05 PM
GI: 1NZ-FE Forged Rods Nexus1155 Forced Induction Forum 41 03-21-2009 03:29 AM
