Old 05-03-2020, 01:38 AM   #3
stidnam
Drives: Starlet
All depends on whether the clock spring has provision for that wire and the body harness that plugs into the clock spring at the bottom has the wire for the speed limiter. I'm not familiar with your Yarii in the UK, but if the same model came with a speed limiter in a different trim, there's a good chance you already have the wiring for it.
Easiest way to find out will be to get a day subscription to this site
https://www.toyota-tech.eu/
Then check the wiring diagram for the model with the speed limiter to check you have the wiring in your body harness. The steering wheel and accompanying trim just need the same plugs as your current one, and you'd want to make sure the wires from the cruise and other buttons all trace back to the same wires where the body loom plugs into the clock spring.
Alternatively, take a punt, buy the wheel, plug it all in and see if it works :)
stidnam is offline   Reply With Quote
TOYOTA STEREO STEERING WHEEL CONTROLS - MULTIFUNCTION UNIT/REMOTE AUDIO CONTROLS chatterbox In Car Entertainment + Electronics (audio / video / alarm) 0 02-10-2012 04:54 PM
Steering Wheel Controls - Part 2! revolution Cosmetic Modifications (Exterior/Interior) 3 11-26-2010 02:53 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 10:16 AM
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
