![]() Drives: 2009 Toyota Yaris Hatchback Join Date: Aug 2020
In my 2009 Yaris 1.5 a metal AC line on the passenger side of the engine bay was almost touching the body of the vehicle at one spot. The line would often rattle against the body on acceleration, it was extremely annoying. The rattle would come and go depending on the temperature and whether the AC was on.
https://photos.app.goo.gl/eXzseCzwWiTwVe8F7 Last edited by Konstantin88; 08-28-2020 at 08:30 PM. |
#2 | |
#3 | |
I have no idea why the horizontal portion is bent, the vehicle has not been in any major collision. |
#4 | |
That horizontal tube can be moved back and forth in the little plastic retainers. Can you maybe indicated on a copy of your pic where the contact is? Nice clean engine bay, btw. ![]() ![]()
May I ask how did you arrange the wood blocks and the crowbar to do the bending?
Thank you, I have recently purchased this vehicle from a dealer, it came with clean engine bay. I would not clean the bay myself. By the way, this Yaris appears to have the same problem as your new RS: the areas of the body where the axle arms attach are pretty rusty, although they are not perforated yet. ![]() Last edited by Konstantin88; 08-30-2020 at 02:04 AM. |
#6 | |
![]() As for the rust at the subframe, my advice would be to get some oil or some other thin oil-based substance in there soon. Rust Check "red" in cans would be perfect. I'd literally unload half a can in each side. It may drip out, so putting an old blanket or something under there might be a good idea. The oblong rubber plugs just outboard of those supports should access the inner cavity. When I am done welding, I plan to drill a hole at the lowest part and install a 1/2" plastic plug. That way I can access the area easily when I do my twice annual rustproofing. Addition: If you do take out those rubber oblong plugs, you might note that the area is filled with sand and debris. I took the equivalent of about a cup of sand and crap out of each side. This is the 'design flaw in this generation of car (hatch, not sure about the sedans). That stuff in there holds water like a sponge.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 08-31-2020 at 11:31 AM. |
#7 | |
![]() I am going to remove the oblong rubber plug and spray this product into the body cavity on each side. How does the debris get into the cavity? Would drilling a hole in the lowest part of the cavity automatically make the vehicle fail the provincial inspection? ![]() |
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
Yaris T1 2007 Knocking Sound | varons666 | General Yaris / Vitz Discussion | 5 | 11-01-2016 04:38 PM |
06-10 Yaris Sedan cold air intake $40 | kylevh21 | Items for Sale by private party | 2 | 04-01-2012 02:14 PM |
Help re my rattling Yaris! | lou3939 | DIY / Maintenance / Service | 2 | 03-11-2012 02:25 PM |
2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 04:54 PM |
