Old 09-30-2020, 04:30 PM   #6
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
That would be the easiest solution undoubtedly. Most people would opt for this approach. I, on the other hand, would be interested enough to actually go through the process as a learning experience and have the satisfaction of doing it. But, I enjoy doing this stuff and I'm already equipped with the tools to do it. Many wouldn't relish the experience.
I agree with the "find one with AC" path, though I do appreciate the sentiment here. ;)
Having gone the other way and removed the AC system from my daily driver, you pretty much have to drop the engine to get the hard lines out of the engine bay. Your engine bay and cabin wire harnesses might not have the wiring for the AC compressor. If the climate control system inside the cabin doesn't have the radiator for the AC, you'll have to dismantle the entire dash board to get to it. That means pulling the A-pillars, steering wheel, steering column, radio/climate control area, speedometer, dash pad, dash bar, passenger air bag, dash wiring harnesses, etc. etc.
It's a LOT of work, even at a junk yard where half the parts have been pulled out already. Most of the wire harness connectors can't be removed without damage, same with the A-pillar clips if you have side-impact curtain airbags. Unless you're in a position to have the car torn apart for an extended period of time and have priced out everything that you need, you're almost certainly better off by just getting a different one. That said, we're always happy to have someone try something crazy and share it with the community!
2008 3 door hatchback rear speaker install question 2bz In Car Entertainment + Electronics (audio / video / alarm) 5 02-02-2019 10:15 AM
What parts are needed to install aftermarket radio? privatecaller Third Gen Yaris General Discussion 3 02-24-2018 05:48 PM
Install AUX on Yaris 2008 Bianco437 In Car Entertainment + Electronics (audio / video / alarm) 15 10-09-2015 10:42 AM
A few small OEM Parts from 2008 Yaris LE Hatch white_rice Items for Sale by private party 0 03-20-2010 05:29 PM
