Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > Yaris TS Talk
Old 10-05-2020, 05:54 AM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Changing the water pump on a TS
Just wondering about the configuration of the TS engine bay. Is there room between the engine and the subframe for removing the water pump? Since my 2ZR engine swap, it looks like I'd have some trouble getting the water pump out. I haven't measured, but I bet there isn't much more than an inch - if that - between the water pump pulley and the frame rail. This is for future reference only as I don't have any issues with the pump at this time. Thanks in advance.
Old 10-05-2020, 10:22 AM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
It's doable at home. I had to drop the passenger side engine mount to get enough clearance and ended up taking off the bumper cover, headlight, fender liner and filler panel next to the radiator to have enough access for my impact wrench. It's a rubber gasket so it's not terrible to take it off and put the new one back on.
Old 10-05-2020, 04:30 PM   #3
06YarisRS
Thanks Sam. Great to know that the engine doesn't have to come out to do it, lol. So, I'm guessing a couple inch drop would be needed to clear the bottom of the frame? Just pop a jack and wood block under the engine, I suppose.
Old 10-05-2020, 05:50 PM   #4
CrankyOldMan
I know I did it in an evening without any real struggles, can't recall exactly how it came out though. I think the impeller can get in the way if you don't have it low enough.
2007 - Water pump suggestions littleblackyaris DIY / Maintenance / Service 1 10-04-2020 08:51 AM
Why the water pump went on my 2009 a theory bronsin General Yaris / Vitz Discussion 19 08-06-2018 12:45 PM
Odd Fuel pump issue. Feeling at a loss. Marchalis DIY / Maintenance / Service 4 03-06-2018 08:55 PM
Location of Water Pump lululovesu DIY / Maintenance / Service 1 10-19-2014 08:05 AM
HELP: changing water pump dlplunkett44 DIY / Maintenance / Service 4 02-06-2011 09:26 AM
