Old 10-19-2020, 11:50 PM   #2
stidnam
Drives: Starlet
What year model are you dropping the engine in?
You shouldn't need to source anything from the US. You can obtain the engine mount through North Shore Toyota in NZ or direct out of Japan through Amayama. Any of the other XD parts with the exception of shifter cables can all be sourced out of Japan given the same car was sold over there as an IST. You also won't need shifter cables if you only change the one engine mount.
The rest of the conversion can be pieced together with corolla parts. I'm unsure if the immobiliser will sync between a zre152 and an ncp91 (assuming this is what you're using), but you can always work around that if you have the corolla immobiliser and key :)
stidnam is offline   Reply With Quote
