Old 10-28-2020, 06:43 AM   #12
gab25diygarage
gab25diygarage
Drives: 2017 yaris NCP150
please do not buy a knocked off air filter ...not doing its job well trust me after a month check your throttle.
never change the diameter pipe of the MAF sensor the oem its design is already programmed on the ecu. if ever you have change the air and fuel mixture will be rich or lean either way you loose power. if you want to change because you want to gain speed well you really need to remap your ecu.(after upgrading the intake, exhaust etc...)
take note: upgrading your intake you must also upgrade you exhaust then to be safe and sure things has change and you can testify as well because it has a record, do the "remapping".
gab25diygarage is offline   Reply With Quote
tooter's manifold adventure... tooter Performance Modifications 1465 07-31-2014 08:11 PM
intake size lunarcrusader Performance Modifications 6 11-06-2009 02:20 PM
The great intake debate! fmicle General Yaris / Vitz Discussion 74 10-06-2009 11:37 PM
