![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
It could be worthwhile to check the door lock and unlock relays.
These appear to be in the Instrumemt Panel Junction Block mounted on the bottom of the Main Body ECU. I think this location is also referenced as the under instrumnet panel fuse location. My diagram shows the relays located next to the 20 Amp "DOOR R/L" fuse, but this may be wrong. One relay is used to lock the doors, and the other unlocks the doors. You can check their operation by swapping the relays.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
#2 | |
![]() Drives: 2015 Yaris Join Date: Jan 2021
So just so Im clear your talking about the fuse box under the hood and not the fuse box under the steering wheel? Because I do not see any relays near the fuse box under near the pedals, unless they’re covered or something. Just for clarification I have attached a pic of where I spliced the wires |
I'm just working from the wiring diagram and drawings in the service manual.
I have attached these for you. Hopefully these will help.
I just went out to the garage and checked on My Yaris. It sounds like the relays are either behind the fuse panel under the dashboard, or inside the body ECU.
The unlock signal should be an earth on pin 10 of connector F82.
| Tags |
| 2015, help needed, keyless entry, wiring |
| DIY keyless entry Viper 211HV w/ pics | tmontague | DIY / Maintenance / Service | 24 | 07-06-2025 09:13 AM |
| Factory keyless entry on the L model? Yes! | Dodge Aries K | Third Gen Yaris General Discussion | 24 | 07-27-2020 02:04 AM |
| Request for DIY Keyless entry and remote start for Yaris 2015 L | YarisCA | Third Gen Yaris General Discussion | 3 | 10-29-2016 11:08 PM |
| Keyless Entry Remotes are dead... now what? | Zanutto | General Yaris / Vitz Discussion | 7 | 01-11-2012 06:17 AM |
| I lost my master keyless entry key, need suggestions.... | Frankd1 | DIY / Maintenance / Service | 19 | 12-02-2010 12:13 AM |
