![]() Drives: Yaris 2006 NCP91R Join Date: Apr 2020
Front suspension boot cover broken
Hey all, was wondering if a loose boot cover on the front suspension will cause any trouble? I see a bit of rust on where the the cover was on normally.
Also, there's a bit of clunking noise when braking with moderate pressure when in drive (light braking is fine) Notes: - car is jacked up - no play in the suspension (3-9 6-12 o clock hand shake test) - no wobbles or clunks when driving normally (only when braking) Edit: brake clunking disappeared when removing the swelled rubber in each lower guide pin caliper Last edited by Branderrp; 10-27-2020 at 11:26 AM. |
![]() Drives: 2008 Yaris 2-Door (White) Join Date: Jan 2014
That nice shinny clean metal shaft will become dirty, the dirt will begin to wear the seal into the strut body (shock absorber part), and the strut will begin to leak fluid and fail. Then you will need to replace the strut. Don't know if the boot can be repaired/replaced (others may know). If "yes", do it. If "no", drive the car till the strut fails and then replace the pair as a set. My $0.02
the boot can be replaced but it is exactly the same job as replacing the whole shock absorber. I would say you can change the absorbers as well. BOTH!
![]() ![]() Drives: Yaris 2016 1.3 Manual Join Date: Jun 2017
i have replaced these boots twice using Toyota genuine part but they fail roughly every 2 years... i dunno maybe because of the under washing which uses pressurized water with strong chemicals???
hope to have other alternative brands that are resistant and will last more than 5yrs... |
| Would these front suspension parts be any good? | Pinchlite | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 13 | 02-09-2017 10:07 PM |
| Get your post counts here! *read 1st post for rules* | Astroman | Off-topic / Other Cars / Everything else Discussions | 3414 | 11-04-2012 09:03 AM |
| Clazzio Seat Cover DIY Install | PETERPOOP | DIY / Maintenance / Service | 31 | 09-10-2010 03:30 PM |
| Torque Settings, front suspension | Nimble | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 02-21-2007 01:00 PM |
| How can I cover front license plate hole | hans_fh | General Yaris / Vitz Discussion | 13 | 01-03-2007 12:58 PM |
