Old 02-06-2023, 07:43 PM   #1
sh0rtlife
between your thread and my perpetual needing to re-adjust the drums..has got me re-thinking disc rears...
now hear me out...stock front yaris rotors put on the rear using XB rear calipers..i belive i could keep my 14inch aluminum wheels..the XB rear calipers solve the E-brake issue without the need for a drum hat rotor....tho i suspect id need an adapter mounting plate similar to yours but 1/4 inch of more offset in the rear of a stock yaris drum beam would square up the wheelbase nicely
Old 02-06-2023, 08:25 PM   #2
Compeer
Drives: NCP90 TRD Yaris Manual
http://www.speedhunters.com/2019/04/...ng-conversion/
Yet another amazing New Zealand build here but this one they show you how they modify there BB to increase track width by just attaching the same tabs as the brake caliper version had.
Compeer is offline   Reply With Quote
Old 02-07-2023, 11:50 AM   #3
Neinris
Nice! But that rear disc conversion uses the drums for the parking brake. My conversion uses the discs as the parking brake.
Old 02-07-2023, 12:01 PM   #4
Neinris
Ultimately…
I the end, here’s what mine will look like:
File Type: jpeg EF9D2B40-79D9-4A36-AA71-B53322500249.jpeg (276.9 KB, 69 views)
Old 02-07-2023, 11:29 AM   #5
Neinris
If you didn't know, the front wheels' track are wider than the rear by 10mm (5mm on each side), adding the 1/4 inch plate will make the rear 2mm wider than the front (1mm on each side).
How would the xB's rear caliper mount on the rear axle frame? Or are you swapping out the axle frames?
Old 02-07-2023, 12:49 PM   #6
sh0rtlife
the issue i ran into when looking at the XA brakes..is the fact that they are all drum in the states but disc elsewhere in the world.....annoying at best
and like you said the bonus is having the caliper be the hand brake and not have a set of drums under it and the second gen XB calipers are setup exactly like that and will sit over the yaris front rotors perfectly....the trick becomes mounting and i "think" there may be a solution to not using a spacer and just welding the caliper mount directly to the beam, its a question of how well the alignment sits for doing so
Old 02-08-2023, 07:20 AM   #7
Neinris
Once I get to mounted and tested for a few months I’ll let you know if there’s any mounting issue. I’m also planning on making another mounting plate for the Yaris SE caliper, which are clocked different than the Corolla calipers.
Old 02-08-2023, 12:37 PM   #8
sh0rtlife
your running the bigger rotors tho right?...i might be intrested in a set of plates from you even if i need to modify them slighty
im hell bent on keeping my 14 inch wheels....but finding a way to make a rear disc fit is looking really good right now...i have to re-adjust the rear drums every month
bonus is i allready have another set of front rotors sitting waiting
Old 02-28-2023, 10:57 AM   #9
Neinris
What issues where you having that you had to re-adjust your drums often? Apparently my drum brakes would over tighten themselves over time, and was causing a bit more of a drag than normal. With the disc brakes, I noticed that I'm able to accelerate a little bit more quicker now, and my MPG has gone up from 31 to 31.5 in just two days!!! That's with my "normal" driving. We'll see how much better it'd get by the end of the week.
Old 02-09-2023, 01:22 AM   #10
sh0rtlife
curiosity why not use a set of fronts?..ive got matching set on the shelf drilled/slotted that i could use...and it seems to me if you had matching front/rear rotor size youd have less brake bias issues..sure youd still need the prop valve and to tweak it to perfection but there would be a whole lot less need to compensate with matched size on all 4...heck i bet you could balance it out some more by useing a "softer" pad in the back than the front
i can get full lock out of the fronts if i really REALLY get on it tho its useualy just 1 not both, so adding brakeing to the rear would be glorious..but im not losing my 14s...so im looking for a solve..and i think youve solved "most" of it
also looking at getting a toaster!..a gen1 xb and i know thats the same parts under it and 14's are most likely what will be on it as well...so if i can make this work on the yaris it would be the same parts on the xb
Old 02-09-2023, 08:55 AM   #11
Neinris
The calipers for the rear (with parking brakes) are made for solid rotors, not slotted, so they're really narrow. Not even the Supra rear calipers would work, their rear rotors are slotted, but only 16mm thick, the Yaris' front rotors are 22mm thick. So I'm curious, what caliper were you thinking of using that would work with the front rotors and has parking brake? Actually, I think I still have my old front rotors, when I get home today I'll see if they fit through the rear calipers slit and post a picture for you.
Old 02-09-2023, 04:39 PM   #12
sh0rtlife
i was eyeballing the second gen XB rear calipers with built in hand brake
Old 02-09-2023, 06:07 PM   #13
Neinris
Which xB, the 2nd GEN? Those rotors are bigger, 279mm, and only 10mm thick. The Yaris front rotors don't fit in the Corolla/Yaris rear caliper by the way. It's too thick. Sorry no pic, I just got home, and it's already dark outside. The MR-2 rear caliper might work for what you're trying to do, but you're modifying the parking brake cable to make it work.
Old 02-09-2023, 06:15 PM   #14
sh0rtlife
oof yeah i didnt think about the thickness..tho your right the mr2 rear caliper looks serviceable
if i could find a "solid" rotor that was thin enough and similar DIA as the yaris fronts that would be ideal but im not sure such an animal exists in the 4x100...the alternative would be to get someone to "mill" down a set of the rears your using down to the same dia as the yaris fronts..but id really like it to be as "off the shelf" as possible
let me know what the max thickness a rolla calipers will fit ?...a bit of digging shows that a possible solution may be mazda miata mx5 rears 251x9mm thick correct center bore..its a question of offset and hub at that point
Old 02-09-2023, 08:40 PM   #15
Neinris
Like I said, the Yaris SE rotors are only 5mm bigger in diameter than the front. Maybe you can get away with using steel braided hoses upfront and regular rubber hoses in the rear to soften the brake pressure in the rear.
Old 02-09-2023, 09:11 PM   #16
sh0rtlife
5mm when your on 14s is ALOT lol when your talking about bigger calipers
i just made note than an 03 prius..uses 255mm rear rotors...prius rotors and calipers should clear, at that point its mounting them..and any weirdness with the hand brake cables
how are you handling the brake cables anyway
Old 02-10-2023, 08:30 AM   #17
Neinris
I'm using the 2012 Yaris SE parking cables, they'll work with the Corolla calipers, that's one of the first thing I looked at before I envisioned the swap. With the exception of the hangers that they come with, they're pretty much a drop in. I'd have to route it differently than the Yaris though, because the mechanism for the Corolla pulls from the top. And the Corolla's calipers has to be clocked around 2 (driver side) and 10 (passenger side) O'clock to point the bleeder valve up. The Yaris' calipers are fine to be at 3 and 9 O'clock since the bleeder valve will already be pointing slightly upwards. See pics below, the shinny caliper is for the Yaris.
Old 02-10-2023, 03:10 PM   #18
Neinris
I just realized I could run just one long rubber hose per side to the rear calipers instead of having multiple couplings. I’ll buy the Corolla rear brake lines and see if they’re long enough.
File Type: jpeg D0B1750D-439F-4CBB-88AD-013458E820E4.jpeg (244.9 KB, 48 views)
Runstop Rear Disc Salvageable? ilikerice Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 05-26-2016 04:38 PM
Rear Drum to Disc Brake Conversion Mark-UPI Wheels, Tires and Suspension Forum sponsored by The Tire Rack 40 03-12-2015 11:26 PM
Questions About rear disc brake system???? jyfro_13 DIY / Maintenance / Service 4 12-22-2009 09:25 PM
