Old 03-25-2021, 01:16 AM   #1
heytim
Drives: 2014 Yaris
Best tape for spoiler?
I'm trying to figure out the best way to re-attach/re-tape my OEM-like spoiler on my 3rd gen hatch. I previously used gorilla brand but it doesn't seem to last very well (tape is still very firmly attached to the spoiler itself, but not sticking to the car side anymore). Prior to attaching, I did wash throughly and wipe down with alcohol but it just doesn't seem to want to stay sticking on the car side.
So just wondering if anyone has any suggestions on which tape would be best/strongest. I'm thinking the 3M stuff, would this be good?
https://www.amazon.ca/gp/product/B00...K6Y9EEQB&psc=1
Or this? Seems less strong though,
https://www.amazon.ca/3M-03615-Scotc...649551&sr=8-26
I've read some people say that it would be a good idea to use an adhesion promoter, but others say it's not necessary and could damage the paint. Any opinions on if this step is necessary?
https://www.amazon.ca/3M-Adhesion-Pr...6645364&sr=8-5
There isn't really a place to drill, nor do I want to drill holes into the car. So hoping of finding a strong/suitable tape solution.
TIA!
heytim is offline   Reply With Quote
Old 03-25-2021, 07:20 AM   #2
Attached mine with 3M 13 or so years ago. Still 100% adhesion. No promoter used.
Old 03-25-2021, 05:54 PM   #3
Neinris
Drives: 08 Yaris 3 Door Hatchback
3M VHB
https://www.amazon.com/3M-Tape-4646-...14952760&psc=1
Be careful, make sure you have everything lined up the way you want, otherwise you'd have a hard time taking it off, or might even cause damage.
Neinris is offline   Reply With Quote
Old 03-26-2021, 03:34 AM   #4
heytim
Drives: 2014 Yaris
Good to know thanks! Do you remember which 3M you used? I guess the promoter is probably way more than necessary then.
Originally Posted by Neinris View Post
3M VHB
Thanks! I'm in Canada and man...US amazon is so much cheaper lol. When I search Amazon.ca for 3M VHB the more reasonably priced ones are random brands '3M technology', not genuine 3M. The ones I posted in my OP seem to be the more reasonably priced ones available on there. The other ones I found were like 10 times the cost of the one you posted
Old 03-26-2021, 08:24 AM   #5
I'd be superhuman if I remembered that. All I can tell you is I got it at Canadian Tire.
Old 03-26-2021, 11:41 PM   #6
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
Toyota drilled holes into the hatch and used anchors along with 3M tape.
Its not as daunting as it sounds. Did you buy your spoiler new from a dealer/supplier? Or is it a used one from a junkyard?
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Old 03-27-2021, 03:21 AM   #7
heytim
Drives: 2014 Yaris
Hahah. I've seen you around here, thought you are close to that :) But yeah, I did check out Canadian tire too, seems they have the 3M molding ones.
Oh, interesting. I'm still very wary of putting a drill to my car lol I'm not that good with tools. But I got the spoiler from someone here a while back, and I can't quite remember if it's a genuine OEM. I don't see any holes for mounting though.
Old 03-27-2021, 12:25 PM   #8
I think this is what I used. IIRC, it was twice as wide as I wanted, so using a fresh box cutter blade, I sliced it in half. Applied around the entire edge of the spoiler mounting surface it provides phenomenal holder power. You do not need to mess with screws.
https://www.canadiantire.ca/en/pdp/3...-0676065p.html
My old thread from when I faced your same dilemma.
https://www.yarisworld.com/forums/sh...ad.php?t=16012
Old 03-27-2021, 04:54 PM   #9
heytim
Drives: 2014 Yaris
Oh that is quite similar to what I have existing lying around here, from Home Depot.
Last time I stuck it on (using gorilla), the tape was wide enough so one strip across nearly covered the entire width. This time though, I think I'll apply around the edge like you said.
Thanks for the link, and mines is definitely not as big as some of the other posters, I weighed the spoiler at about 2 lbs only so pretty light
Old 03-27-2021, 08:04 PM   #10
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
That 3M tape will be plenty.
I bought mine straight from the dealer with the mounting stuff and templates included, so I just installed mine like they do from the factory. Easy peasy.
2014 NCP131 5 Speed
Strange tape where the spare tyre is kept mikastefh General Yaris / Vitz Discussion 8 06-15-2010 07:48 AM
Double side tape from visors DandiDani General Yaris / Vitz Discussion 12 10-15-2009 07:49 PM
Nerd Mating Dance (caught on tape) m911gt Off-topic / Other Cars / Everything else Discussions 33 04-07-2009 11:38 AM
Super Wide 3M Double Sided Tape blacksan Cosmetic Modifications (Exterior/Interior) 3 05-18-2007 02:36 PM
