Old 04-22-2021, 04:40 PM   #1
2010yarisHBbase
Drives: 2010 toyota yaris hatchback
2010 yaris hatchback base lowering springs or coil overs?
hello friends, I am on a tight budget and would prefer to spend less but I dont want low quality either. I am looking for good lowering springs for my 2010 yaris hb or coil overs but I dont know a good brand. I am in California. what do you guys think is better the springs or coil overs?
2010yarisHBbase is offline   Reply With Quote
Old 04-25-2021, 09:50 AM   #2
tmontague
tmontague's Avatar
Springs 100%.
If you want quality but are on a tight budget then coilovers ate out of the picture.
Old 04-25-2021, 04:48 PM   #3
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150
I have a set of Megan Racing springs on my NCP131 running stock struts. Rides nice and looks good. Definitely go with springs if you're on a budget.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
Old 04-25-2021, 06:55 PM   #4
2010yarisHBbase
THATS WHAT I ORDERED!!
Old 04-25-2021, 06:56 PM   #5
2010yarisHBbase
Originally Posted by tmontague View Post
Springs 100%.
Ive seen you on the form before, thank you for answering! I have a question about your swapped car. how hard was the swab and how much power does the engine make? is it turbo'd?
Old 04-25-2021, 07:26 PM   #6
2010yarisHBbase
do the springs make the car bouncier?
Old 05-05-2021, 07:33 AM   #7
tmontague
tmontague's Avatar
It probably makes around mid 130's to low 140's whp. I've never dyno'd it, that is based off of my best guess relative to Tom Armstrong's set up that he dyno'd.
It is not turbo'd and never will be, I want to keep it reliable for the track.
The swap is probably as "easy" as it gets for putting a different engine in a car. That said it's all relative to your skillset, experience and tools. No matter what there will always be issues and troubleshooting you need to do. In my case I had to find a shorter axle as I had axle being issues that no one else seemed to have.
Old 05-05-2021, 11:59 AM   #8
Neinris
I have the Tein's lowering springs currently with the stock struts, and it does make the car bounce a little and oscillate after going a speed bump, but not too bad. Quite a few here uses the Bilstein B8 shocks with their lowering springs and are happy with it, so I'll be doing the same thing in the near future.
Old 04-22-2022, 01:56 AM   #9
2010yarisHBbase
how did you get to the front springs btw? did you have to take off the front wipers?
Old 04-22-2022, 03:42 AM   #10
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Requires removing the wiper arms, wiper cowl and drip tray, Its super easy. The entire wiper linkage assembly and motor lifts out after removing the bolts.
I can't remember exactly what sizes but definitely have a 10mm, 12mm and 14mm with you along with an extension.
2014 NCP131 5 Speed
2010 Yaris Liftback (LB) / Hatchback - Prewired for Trunk Actuator? bad_bwoy007 DIY / Maintenance / Service 26 01-18-2021 06:09 AM
WTB: Microimage lowering springs for 2008 yaris 3dr Nanay'scar Willing to Buy by private party 0 10-17-2016 04:33 PM
