Drives: Toyota Yaris 2007 Join Date: Jul 2021
Hello,
I own Toyota Yaris 2007 and in the service manual it is noted that the clutch pedal free play can be adjusted by loosening the lock nut and turning the push rod until the correct free play and push rod play are obtained. However in my car configuration there is no such nut. Please see the figure attached. Normally most of the master cylinders have it. Is it possible to make such adjustment in my case? Thanks! |
| Clutch shudder when setting off in 1st gear | BuildCode | DIY / Maintenance / Service | 87 | 06-17-2015 07:14 AM |
| Help Me Find The Right Clutch | RacerFreakXXX | Performance Modifications | 18 | 10-20-2010 05:20 PM |
| Restarting car after popping the clutch... | PaidTimeOff | General Yaris / Vitz Discussion | 21 | 02-26-2009 01:40 PM |
| Having clutch issues ? | hystria | DIY / Maintenance / Service | 10 | 08-22-2007 11:34 AM |
| c one motorsport clutch line(pics) | badhabitz | Performance Modifications | 6 | 07-31-2006 10:08 AM |
