Old 09-04-2021, 09:01 AM   #10
Gragento
Newbie
Drives: Toyota Yaris High Pack 1.4 d4d
Plastic of the Trunk
This should help (from the 09 service manual):
Using a screwdriver with its tip wrapped in protective tape, slide the handle plate of the back door trim board to disengage it.
Disengage the 3 claws and 9 clips and remove the back door trim board.
REMOVE BACK DOOR PANEL NO.2 PROTECTOR
(a) Disengage the claw and clip, then remove back door panel protector No. 2.
Remove any tape remaining on the back door side.
Do you or anyone else have the same manual remove this panel for its alignment? There are 2 fixing Pins, just remove them and you're done?
Attached pictures or here:
https://drive.google.com/file/d/1liV...ew?usp=sharing
https://drive.google.com/file/d/1Q8K...ew?usp=sharing
Gragento is offline   Reply With Quote
rear doors hatchback speakers yv1650c In Car Entertainment + Electronics (audio / video / alarm) 1 05-01-2007 05:22 PM
Rear Center Toyota emblem removal spkrman Cosmetic Modifications (Exterior/Interior) 8 01-11-2007 12:37 PM
-- Liftback Rear Speaker Removal? -- rarmogan In Car Entertainment + Electronics (audio / video / alarm) 2 09-25-2006 03:48 PM
