Old 08-12-2019, 05:04 PM   #1
nomad
Drives: 2005 Toyota Vitz RS
Exclamation Retorque ARP head studs turbo build
Hi guys first post in here. Need some help.
Anyone know if I can retorque ARP head studs
Without removing the camshafts on 1nzfe?
Just about finished run in for new build and
Will need to retorque but don't know if cams need to
Be removed. All I know is that arp head studs are
Made so that they can be retorqued without needing to
Remove camshafts but unsure on our engines.
Thanks in advance for your help!
nomad is offline   Reply With Quote
Old 08-12-2019, 07:19 PM   #2
Jason@SportsCar
Cams are in the way of the head bolts. We also found we could not use a complete set of ARP studs because the bolts they include are so tall they hit the CAM timing wheel and block the VVTi passage, so we mix them with OE bolts.
Old 08-13-2019, 04:08 AM   #3
nomad
Great thanks for your help Jason.
Old 08-15-2019, 07:38 PM   #4
Tima122
Drives: bB NCP 31 2005 y
1. Потребуется немного сточить клапан vvt-i, потому что шпильки ARP больше в диаметре.
2. Потребуется уменьшить диаметр впускного вала у первой крышки распредвала. Так как гайка ARP слишком высокая.
3. Для замены стандартных болтов крепления головки блока цилиндров распредвалы снимать обязательно.
Tima122 is offline   Reply With Quote
Old 06-24-2020, 04:56 PM   #5
Zedicus
Drives: scion xb
the 1nz ARP kit needs 3 of the nuts ground down too fit.
ALSO you will need to notch the end off of the VVT-i solenoid as it hits one of the nuts.
cut the side of the nut where the socket goes, NOT the side that makes contact with the head.
i did not want to use the OEM spring bolts mixed with the ARP as they would apply different amount of load. cutting the top off the nut does not change any properties affecting torquing or loading on the build.
the ones that go here need about 1/8" cut off the TOP of the nut. otherwise they hit the cam.
Zedicus is offline   Reply With Quote
Old 11-30-2021, 04:57 AM   #6
levanarosGR
Drives: yaris ts 2005
Hello guys, can you give me some more specific information about how to notch the solenoid valve without damaging it?
levanarosGR is offline   Reply With Quote
1nzfe, arp head studs, forced induction, re-tourqe
Want to build costom turbo kit. Need advice from boosted guys! pimp my yaris Forced Induction Forum 639 09-28-2013 12:26 PM
Chevy Aveo RS: Turbo + good looks = build it! Thirty-Nine Off-topic / Other Cars / Everything else Discussions 22 01-12-2010 01:36 PM
Turbo Project Yaris TS 1.8L CASTREX Yaris TS Talk 40 08-21-2009 11:24 AM
build up for a turbo redduck Forced Induction Forum 15 07-02-2007 10:31 PM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 03:26 PM
