#20 |
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Feb 2019
If you've removed the coils, then you're capable of diagnosing the spark plugs. The engine can run with the spark plug removed and the injector unplugged. Try a cylinder drop test with each component, and look and test the spark plugs. It's criminal to take the coils out and not take the spark plugs out for inspection
| Tags |
| coil, maf, p0302, spark plugs |
| Misfire cylinder 3-4 yaris 2007 | vandammages | DIY / Maintenance / Service | 0 | 05-09-2017 08:57 PM |
| Cylinder 1 misfire and catalytic converter issue | Lu Xun | DIY / Maintenance / Service | 3 | 08-24-2013 06:37 AM |
| Misfire into multiple cylinder! | maxthehax | Forced Induction Forum | 21 | 12-12-2012 12:18 PM |
| P0300 Random / Multiple Cylinder Misfire DetectedCylinder 3 misfire | dante2086 | DIY / Maintenance / Service | 4 | 05-15-2011 04:36 PM |
