Old 02-21-2022, 06:43 PM   #1
loikol
Drives: BMW
Don't worry. You can lubricate the electric power unit and the hydraulic power unit to eliminate squeaky noise and extend the service life. You should use Litol, a universal grease for all mechanisms for this purpose. In answer to the question about the new car service, I can say that you should pay attention to CRM. It is software that will allow you to serve your customers much faster and better. The CRM also allows you to control all the operations in your car service. You can read more information about it on the Internet. I wish you good luck!
loikol is offline   Reply With Quote
Tags
eps, gear, noise, power steering, steering gear
Smooth gear transmission AnaKara DIY / Maintenance / Service 4 07-30-2019 11:25 AM
2014 Mazda 3 Kal-El Off-topic / Other Cars / Everything else Discussions 32 11-08-2013 01:51 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 11:16 AM
Gear oil change choices (Canadians) Jem_hadar DIY / Maintenance / Service 17 08-29-2009 12:51 PM
