Old 05-15-2022, 06:46 PM   #1
MoondanceR
Drives: Toyota Yaris 2010
Suggestions for good battery brand
Hello
I serviced my car the other day and they told me that I need to replace my battery asap. Any recommendations?
Thank you in advance for your help
MoondanceR is offline   Reply With Quote
Old 05-16-2022, 11:26 AM   #2
remcafee
interstate batteries seem to last the longest
Old 05-16-2022, 03:56 PM   #3
MoondanceR
Thank you for your answer.
There are many factors that I don't understand. Suck as size (dimensions), battery capacity, Cold start current, etc.
When I entered my car's registration info into a car parts website, I got 4 different options, with AH ranging from 42 to 92.
My car is a Yaris 2011.
Old 05-17-2022, 07:20 AM   #4
ex-x-fire
The colder the climate, the higher the CCA (cold cranking amps) you want.
You need the correct size to fit in the location. Use the battery group number to determine that.
Old 05-17-2022, 01:33 PM   #5
remcafee
you need a group 35 battery, if you have the originsl battery bracket that fits group 35
Old 05-18-2022, 04:55 AM   #6
bronsin
bronsin's Avatar
In my experience the battery that lasts longest are the ones that come with the vehicle as original equipment. Typically seven years! Replacement batteries seem to go about four years.
Old 05-18-2022, 09:19 AM   #7
esse10
Drives: 2009 yaris 2 door
battery
you get the most bang for your buck at walmart. If the local parts store sell you the same CCA as walmart but at different price , why not go with lower price.
Old 05-18-2022, 12:41 PM   #8
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
OP is in EU. No Walmart or Interstate battery. Might not even be a group 35 depending on engine. They don't have the 1NZ-FE there.
NYC-SE is online now   Reply With Quote
Old 05-18-2022, 04:06 PM   #9
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
I'm still running the original battery in my 2014 lol
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
Old 05-24-2022, 06:23 AM   #10
komichal
European here, 2SZFE engine.
I am using Varta C22. Right size and distance of battery terminals. 60 USD.
Sweden might be a bit colder than Central Europe where I reside but I have started my car up easily in -25 degrees. You can crank those small engines up with anything.
Brand new battery drained RubySlippers33 DIY / Maintenance / Service 10 05-12-2012 09:48 PM
