Old 06-22-2022, 02:35 AM   #11
Vyaris07
Vyaris
Drives: Yaris-2007 1.5L Auto 3doors
Wink P0441 code fix How-to
My Yaris 2007 got issue with P0441 code, read this forum and figured out the EVAP canister rubber is degraded, then :
1. Remove gently the canister out.
2. Wrap each very-end with office 1/2" wide clear-tape about 3-4 turns.
3. Re-insert the canister pipe back gently.
4. Bought two spring clamp 3/8" size, put on at least 1/4" from each end.
5. Run engine and turn on the code reader, clear the P0441.
6. Check the gas cap for clean-up the O-ring seal, then tied it up with 1-2 clicks.
After running idle for 5 min, read the code again, as result, no more P0441!
DIY is easy as this task!
Vyaris07 is offline   Reply With Quote
EVAP leak detected? eepp DIY / Maintenance / Service 7 01-29-2018 01:42 AM
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 02:15 AM
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 09:02 AM
