![]() Drives: 2011 Yaris Join Date: Jan 2022
I have a 2011 Yaris that abs engages when I firmly press down the brake on dry roads. I took out and cleaned the ABS sensors and put them back in and still got the same results. Anyone have an idea on what else it could be?
If you're hitting the brakes firmly then are you near the point of lock up? It is winter in Wi after all.
![]() ![]() ![]() Drives: 2015Yaris, Son's car, 10 Prius Join Date: May 2010
Your tires can still lose traction on a dry road. Also a lot to due on how old your tires are.
Much appreciate it, I just felt that abs engaged to easily when compared to my civic.
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
Mine has always had the premature abs problem. In the snow, it is worse.
My old Echo was a much better car. |
| Tags |
| abs, abs sensor, braking |
| ABS Code Keeps Returning After Sensor Replacement Code 31 Front Right | Chwbcca | DIY / Maintenance / Service | 5 | 09-15-2021 09:16 AM |
| Abs engaging at low speed | Mike003 | DIY / Maintenance / Service | 10 | 08-20-2019 04:37 PM |
| First Generation Vitz ABS Issue | Owais Yunus | DIY / Maintenance / Service | 0 | 10-29-2016 12:14 PM |
| Noise From ABS when Braking + ABS & (!) Light On - Please Help | Chris Jackson | DIY / Maintenance / Service | 2 | 04-23-2016 01:00 AM |
| What's with ABS? | jgag123 | Canada | 9 | 01-01-2009 07:04 PM |
