Old 09-14-2022, 01:42 AM   #9
remcafee
so any engine from a 10th gen corolla, and scion xd would be the 2zrfe engine, if you get a motor from an 11th gen corolla you risk getting a valvematic motor which is probably gonna be more of a hassle to swap, also if i remember correctly the 2zrfe has a facelift variant startingin 2015 in which it has a some different styling cues and different oil filter housing bracket setup for a spin on oil filter, and a revised intake manifold. it should not matter at all but their is some changes to later model corollas with the updated parts which might a be a little better if you can get.
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 04:59 AM
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
3rd gen engine swap, 2ZR? 2AR? Swap newbie m.flores.0928 Third Gen Yaris General Discussion 6 10-02-2020 10:54 AM
06YarisRS's 2ZR-FE Swap 5-Door Hatchback (Automatic Transmission) 06YarisRS Performance Modifications 448 12-06-2018 08:12 PM
2zr swap and e-test in Ontario tmontague Performance Modifications 7 12-23-2016 09:12 AM
