Old 10-20-2022, 05:24 PM   #40
sh0rtlife
for hatchback owners, theres a TON of room up under the dash just to the right of the heater behind the glove box, in fact theres enough room to mount 2 600watt amps, ive got 1 in there right now
i would assume the same space is availible for the sedan but cant say for sure
600watt unit up there with 2 hand made ultra slim boxes mounted under rear seat delete under the aluminum plate with a pair of 8s , due to the maze port design with a square port opening aimed about center of the car faceing forward, the output is ASTOUNDING..ive had multi thousand watt systems in the past with 15s 10s etc, i had one rig with 3500 wats in the 90s, and to be fair this does better than the 15inch sub box i had in my truck, with GREAT clarity
while its maginaly a single box in the fact that i kept a back brace panel connecting the boxes its 2 12x15x 7 inch boxes..yeah the are THIN but theres a diviot in the floor where the back seat would be that gives a nice pocket for the speaker face to be aimed down in as well reflecting sound to the front sides of the car kinda thru the bolster area
i built the setup as an experiment and im blown away
srs / airbag light after head unit install? KwonSau In Car Entertainment + Electronics (audio / video / alarm) 7 12-24-2008 02:04 AM
Req: Head unit suggestions. xed In Car Entertainment + Electronics (audio / video / alarm) 21 08-09-2007 07:38 PM
High pitched whine using stock head unit / aux input? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 8 02-02-2007 12:49 PM
